Home > Technical > Td5. Brake pipe |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I use copper and bought a standard flaring set. I used it on my disco 3 and 90 td5. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
15th Apr 2019 4:08pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
I always use Kunifer pipe and make my own. Sykes Pickavant flaring tools are generally the best.
15th Apr 2019 4:52pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 558 |
I always use Kunifer, (cupro nickel) it doesn't work harden like copper.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
16th Apr 2019 11:19am |
divethedeep Member Since: 17 Sep 2014 Location: sussex Posts: 32 |
Thanks all
Brake pipes now replaced I purchased a roll of copper pipe to start with but changed my mind after reading reviews on different brake pipe materials I retuned the copper and ordered a roll of cunifer pipe I ordered the Sykes pickevant flaring tool as recommended I discovered my defender has metric fittings (din) so had to return the selection of fitting I purchased as imperial There was quite a lot to learn about different types of flares. DIN. SAE SINGLE AND DOUBLE FLARES and the threads are very similar ie an imperial end will fit into metric but feels very flopppy Armed with my new Sykes pickervant tool cunifer pipe and new inexpensive bending tool The pipes acros rear axel were changed , front offside and I replaced half of the pipe rear to front putting an inline connector half way as front section was not corroded Thanks mark |
28th Apr 2019 7:34am |
Good work.
28th Apr 2019 9:12am |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Checking the connectors is easily overlooked
Here was mine, luckily I noticed dripping before anything bad happened.. Click image to enlarge Click image to enlarge You can always gently use the handbrake as a way of stopping the car quickly if you have no time for engine compression. |
7th May 2019 5:58pm |
