![]() | Home > Wheels & Tyres > Tyre pressures on 7.50 x 16 |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Simply make the chalk test and vary for your convenience within the good range. Never forget: cars have owner, Landrover have field service personnel.
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
try this
Tire sizes Model Tire size 90 205/80 R16 Radial 265/75 R16 Radial (Multi terrain) 7.50 R16 Radial 110 - except Japan 7.50 R16 Radial 110 Japan 7.50 R16C 130 7.50 R16 radial Tire pressures Model - Tire size Front Rear 90 - 205/80 R16 1,9 bar 2,6 bar 28 lbf/in! 38 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm! 90 - 265/75 R16 1,9 bar 2,4 bar 28 lbf/in! 35 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm! 90 - 7.50 R16 1,9 bar 2,6 bar 28 lbf/in! 38 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm! 110 - 7.50 R16 (except Japan) 1,9 bar 3,3 bar 28 lbf/in! 48 lbf/in! 2,0 kgf/cm! 3,4 kgf/cm! 110 - 7.50 R16C (Japan) 2,2 bar 4,1 bar 32 lbf/in! 60 lbf/in! 2,3 kgf/cm! 4,3 kgf/cm! 130 - 7.50 R16 3,0 bar 4,5 bar 44 lbf/in! 65 lbf/in! 3,1 kgf/cm! 4,6 kgf/cm! BM52 |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 ![]() ![]() ![]() |
Ta awfully!
