Home > Puma (Tdci) > Cabin air con/ventilation filter? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
There is no filter, and I suffered the same from Morocco. Before my next trip I am going to by some open cell foam like might be used in a fish tank filters. I’m going to cut it so it can be inserted up into the snow cowl to see if that will function as rudimentary air con filter that can be easily pulled out and washed as required. Might clog really quick, but it is worth a try. 2007 110 TDCi Station Wagon XS
15th Apr 2019 6:57pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 733 |
On the cabin side, you can buy those filter sheets for window type air conditioners and cut them to the size of the hole under the dash, use thin double sided tape to stick them on and replace as necessary.
16th Apr 2019 12:35am |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 |
look on Devon 4x4 site, they do a filter that sits where the wing vent is
16th Apr 2019 5:36am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1071 |
Do you mean this? https://www.devon4x4.com/d44-defender-cab-filter-black-lhd.html
Seems interesting, also because they provide a pollen filter (atchoo). However, the filter seems to be quite exposed? |
16th Apr 2019 12:14pm |
thats it, not the prettiest but does the job, just wash out the foam filter and refit - stops all the dust blowing in
17th Apr 2019 7:02am |
Exwirus Member Since: 11 Dec 2017 Location: Bydgoszcz Posts: 7 |
Click image to enlarge Hi guys. There is a new solution to the problem of the lack of a cabin filter. Tested in dry and wet climates. works very well and filter cartridges are available in every automotive store. https://shop.otc4x4.eu/en/products/cabin-f...ack-9.html |
2nd Nov 2021 5:11pm |
Looks a bit weird with the snow cowl perched on top. 2007 110 TDCi Station Wagon XS
2nd Nov 2021 5:25pm |
But it does the job, filter stays dry even when driving in heavy rain...no leaves on the A/C evaporator
2nd Nov 2021 6:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20302 |
Was just about to suggest that. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
2nd Nov 2021 6:05pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Not a great aesthetic TBH. Rgds. Chris |
2nd Nov 2021 6:56pm |
Click image to enlarge Black one with wing top plates is less visible but aesthetics is very individual, of course |
2nd Nov 2021 7:12pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
Be warned that the more filtration you fit to the system on a puma where the filtration is on the vacuum side of the blower, the more engine bay air you suck in through the horrific ducting.
I had the Devon 4x4 one fitted before I "fixed" my duct. Great in principal. In practice it just sucked much more through the gaps in the ducting due to the pressure drop being greater as the filters on the end. |
2nd Nov 2021 8:23pm |
