Home > Maintenance & Modifications > Ifor fitting question. |
All Terrain Member Since: 22 May 2011 Location: Poole, Dorset Posts: 92 |
Should the holes for the hood sticks be ground flush with the top of the pick up tub in order for the canopy to fully contact the tub?
Just wondered. |
20th Jun 2011 5:58pm |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
Mine sits nicely on top of the hood stick holes. The lip is deep enough to still sit over the cappings and the seal (ish) against the cab back is lined up about right (ish) at that height.
By "ish" I mean "with LR Manufacturing Tolerance" or "you can drive a bus through it". 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
20th Jun 2011 6:08pm |
Ah ok well that is what mine does and seems stable with the same tolerances that you mention. The onlt reason I asked is that the Ifor tailgate and the LR tailgate have about a 10mm gap between them which appears to be about the same as the tops of the stick holes. If they were ground down then they would meet (almost).
Supposed that would throw out the precsion fit of the rest of the canopy! DJ |
20th Jun 2011 6:26pm |
My typing is about as precise as the canopy fit!
20th Jun 2011 6:27pm |
Blackwolf,
Good advice thanks, just had a closer look tonight and spotted the rubber stops that the canopy sits on and allow it to clear the stick holes. Must say I just chucked it on when I picked it up today. Must say it has transformed the look of the vehicle. Cheers, DJ |
20th Jun 2011 10:25pm |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 |
AT, would you mind posting up a pic of your DC with the top fitted please? Trying to decide to get a DC and the IW top is an option, but can't really find any decent pics of one fitted.
Mark 2011 110 XS DC Stornoway Grey |
26th Jun 2011 9:44am |
MM, will take some tomorrow and post them up for you.
Cheers, AT. |
3rd Jul 2011 4:23pm |
MM can you PM me your email address and then I'll email you the images as posting here is a bit long winded.
Cheers, David. |
4th Jul 2011 9:06am |
The DC is now top of my list (even seen one I'm going to buy should my D3 suddenly find itself sold), so would be good to see the piccies.
Just PM'd you Mark 2011 110 XS DC Stornoway Grey |
4th Jul 2011 4:49pm |
