Home > Technical > Rear anti-roll bar bracket unintended modifications ...
Thon
I had a little spare time today and started to give the 110 the first proper underbody clean for 2 years, and at the same time switch wheels to my A/Ts and alloys. I jacked the back up onto axle stands and washed away merrily for 30 minutes or so, and then gave it a chance to dry off a bit. Went to inspect my handiwork and found that both ARB links were badly distorted and pushed into the rear of the spring seats, luckily not crushing the brake pipes: -
and on inspection found the reasons why: -
Both chassis brackets had been distorted, presumably in one of my adventures, probably whilst being winched across something unyielding. More annoyingly, Land Rover's insistence in using 8mm bolts with a 10mm AF hex heads proved that the best tool in the box seems often to be the angry grinder Shocked Both sides were bent and the ARB was rubbing on the tank guard. I plan to replace the brackets with new as they're fairly well bent and whilst they could probably be beaten back into shape they won't be as strong.
Post #768472 13th Apr 2019 9:37pm
Damn, is the ARB itโ€™s self damage free and straight and true?
Iโ€™d agree the brackets need replacing, the welds are probably highly stressed now.
Must have been quite a hit to invert the links like that! $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #768480 13th Apr 2019 10:11pm
Thon
I haven't checked the bar itself yet - was more interested in getting it off than anything else. I was winched across a number of ridges where we had bellied out so I guess it was one of those that did it. I'd prefer to leave it off permanently (together with removing the front) but I guess the implications on insurance would be a concern. As you say, brackets and their welds are looking decidedly secondhand so we'll get them replaced.
Post #768486 13th Apr 2019 10:45pm
miker
Whilst insurance concerns are valid, mine, and I believe many others, never had a rear ARB from the factory!!
Post #768534 14th Apr 2019 12:26pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
What concerns are those?
Mine doesn't have ARBs... I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #768553 14th Apr 2019 2:14pm
miker
The concern would be that removing the roll bars would class as a modification, and possible one that insurance wouldn't be happy with. But as there's no rule on which defenders did or didn't get delivered with roll bars, or any way of telling if it ever had roll bars, then there's little way for it to be proven what is and isn't original
Post #768556 14th Apr 2019 2:30pm
That is in fact a reasonably common problem due to the flimsy nature of the chassis mounts. I've seen it a few times.
Post #768568 14th Apr 2019 3:35pm
jst
Worryingly I have also seen it before. Arb bushes failed at axle end bar end locked up against back of spring. Then when trailing arm Bush failed it forced chassis mounts back like this. Was only on one side though. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #768588 14th Apr 2019 5:25pm
Thon
It's not a concern from the vehicle dynamics aspect, my first 2 defenders and a gazillion others did not have them - it's only that this one was fitted with ARBs from the factory and to remove one could be seen as a modification. I suspect should the insurance company go digging with the original build documentation, they might find it and cause trouble. I'm not keen to give the insurance company an excuse, should push come to shove ....
I checked the bar today and found that the main bar is straight and one mounting tab is slightly bent - nothing of any concern. I measured it as 28.5mm diameter and it's orange so I guess it's also aftermarket, as were the springs it came with originally. Brackets definitely bejiggered and will be replaced.
Post #768623 14th Apr 2019 8:52pm
roel
You might be able to find your build specs if you download a version off microcat which is newer then your Defender. And check your vin. You might need an older computer to get it running and set the date to the date that is applicable to the downlaoded version. Mr. Green
If the ARB's are not on there the insurance company can not see if your were fitted or not. Roel
2003 90 Td5 (2009-now)
Post #768695 15th Apr 2019 4:06pm
^^^ Unless they are reading this thread!
Post #768703 15th Apr 2019 4:54pm
MikeN
South Africa
ARB arms has "flipped" due to suspension over-extension. Lifted suspension with longer shocks? Mike Nieuwoudt
1989 110 V8 SW
Post #771635 5th May 2019 4:43pm
Thon
No, I don't think so, not in this case.
It was winched several times across some hard ridges, which I suspect forced the lower ARB links backwards, bent the chassis brackets and pushed the ARB upwards.
Suspension is standard, both springs and dampers, so over-extension isn't really possible without breaking damper rods/eyes.
Post #771678 5th May 2019 8:59pm
