Home > Maintenance & Modifications > Hardtop loadsoace matting options |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
I cut down a thickish (3/4 inch roughly) rubber stable mat for the back of my old 110 300tdi Hardtop, certainly non slip and damped the noise down alot. Cheaper than most alternatives as well.
12th Apr 2019 4:28pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 737 |
I also used stable matting from my local country store, two thicknesses available, I used the thinner one.
I think it was about £40/sheet a couple of years ago. |
12th Apr 2019 6:22pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Thats what i use in the back of my pick up to give the dogs a bit of cushioning from the chequer plate. Definitely non slip.
12th Apr 2019 6:23pm |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 264 |
I got some pre cut, checker plate effect plastic matting with the edges hemmed for £10 from Newbury 4x4 show last weekend. I'm very happy with it , especially for the price. I plan on fitting the rear with soundproofing and carpet soon to go under it
12th Apr 2019 6:45pm |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 234 |
watching with interest - horse matting sounds the ideal solution - is it easy to cut? A friend recommended gym interlocking mats.
I have linexed my floor but my dog slips on the surface - it doesn't scratch it but isn't handy for her. |
12th Apr 2019 8:47pm |
Cut mine with a carpenters hand saw
12th Apr 2019 9:24pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 520 |
+2 and it made a massive difference to sound deadening |
13th Apr 2019 7:43am |
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 |
Click image to enlarge I used a sound insulation and then added ply wood which i screwed down although i do use it for work ie mowers etc but you then could put a mat on top Click image to enlarge |
13th Apr 2019 8:36am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2640 |
I have a piece of rock crusher conveyor belt in mine. 3/4” or so thick and very heavy.
Same principle as the stable matting, but free |
13th Apr 2019 1:24pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Stable matting is a good idea for load area flooring but it is heavy, an advantage 'cos it doesn't move around but it is not the easiest material to cut. Defender 90XS SW
13th Apr 2019 5:55pm |
