Home > Puma (Tdci) > Roof re-seal |
Interested also Solved the bowel problem, working on the consonants...
12th Apr 2019 2:00am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20441 |
I would look at Uplol Tiger seal. $W33T $0U7H3RN $UG4R
12th Apr 2019 8:39am |
richg Member Since: 01 Aug 2016 Location: Southampton Posts: 18 |
Did they take the roof off?
A few years ago I had a puma roof painted and they didn't take it off. Results were great and still looked good when I sold it several years later. About to have my current pumas roof painted and cannot decide if they should do a roof on or off jib |
25th May 2019 8:35am |
A few years ago I had a puma roof painted and they didn't take it off. Results were great and still looked good when I sold it several years later. About to have my current pumas roof painted and cannot decide if they should do a roof on or off job |
25th May 2019 8:36am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
Foam strips with a healthy bead of Tiger seal. Once in place and bolted down Tiger Seal along the inside seam as well as seam where two foam strips meet.
25th May 2019 9:23am |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 |
The roof did indeed come off and the sides were just sealed using the rubber seal like from factory and the front above windscreen had a bead of sealant run along it. Will get some close up photos when I get the chance. It was a really neat finish.
25th May 2019 10:10am |
