Home > Maintenance & Modifications > Modifying the power lead from the battery to the fuse box
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi all I am looking at a way to re-root the fuse box live cable from the battery?
Has any body got any suggestions to help me?
Cheers Ash
Post #709280 26th May 2018 9:35am
mk1collector
Lrd security do a full kit. Ray
My build thread
Post #709284 26th May 2018 10:59am
Landyash
Thanks for the reply mk1collector its more of what route to take has the battery and fuse box lids are metal,
do people just trim them to let them come over the top?
cheers Ash
Post #709289 26th May 2018 11:35am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I ran mine through the back of the battery box, then drilled up through the floor behind the box and ran the cable inside behind the seats and followed the same route down into the other seat box 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #709297 26th May 2018 1:12pm
mk1collector
There should be a grommet next to both of the seat box lids in the seat box itself that xs defenders use for the heated seat wires. You can either replace these for grommets with holes in the centre or try and drill them out. Thumbs Up Ray
My build thread
Post #709338 26th May 2018 6:16pm
Landyash
Thanks guys I will give it a go👍🏻
Post #709352 26th May 2018 7:35pm
DSC-off
On a vehicle with heated seats it's possible to drill another hole behind the seat wire hole.
A cone cutter is probably the easiest way to get the right size hole for the new grommet.
Post #709412 27th May 2018 10:15am
Landyash
Thanks DSC-off I have heated seats so will try your way 👍🏻
Cheers Ash
Post #709441 27th May 2018 3:05pm
nitram17
Just found this ... for others info..... i simply moved the heated seat wire and grommet forward to a ready made duplicate hole and cable fixing point near the front of the seat box (the plastic retaining cable clip next to the grommet requires turning a little then it will pull out).same on the other side side! bought some 25 mm grommets from tool station £3 for 100 ( i do have some spare Laughing )as i wasnt going to pay 4 quid for two on fleece bay.........My heating loom was long enough to move the cables ..no need to drill anything.......... If you have the newer fusebox the plastic cover of the Positive feed to the fusebox is a Censored to get off without breaking it ,if anybody has a part number for itand would be willing to share i would be a very happy man for at least a micro second ?
if anybody has a part number for the cover where the white arrow is or has any idea what its called as i have tried most descriptions and cannot find it online!
Post #768047 10th Apr 2019 5:35pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
nitram17 looks really tidy. Thumbs Up
Did you use the LRD Security kit or buy cable, etc separately?
Post #768051 10th Apr 2019 6:20pm
nitram17
Hi JPE I used the LR security product but i bought it last year and did not fit it till last week Embarassed Embarassed they might have updated it since then(they did not reply to my e mail so i doubt it)if you have a later fuse box the isnstructions were wrong and the fuse box end had a 6mm hole that needs to be 8mm...one end has a 90degree end which is awkward but still fits........... given that it was easy to fit (except for plastic cover to lead on fuse box)and moving seat heater loom.
In hindsight given that they did not reply to my e mail and the kit supplied had to be modified i woud save some money and either make it up myself or get someone local or ask paul on here to do it for you ..after all its a length of wire mimimum 25mm2 thick with sleeving and a couple of metal couplings and a few p clips ..you could do it yourself fo £25..............i chose the off the shelf version to save time!
Post #768081 10th Apr 2019 8:35pm
JPE
Thanks, much appreciate the advice. I've been trying to weigh up getting the kit or just buying some cable and bits. Your photos are really helpful to see how to route the cable. Thanks.
Post #768094 10th Apr 2019 9:34pm
nitram17
Hi JPE.. just one addition ..i dont know how old your truck is ..if you have the old fuse box the fixing at the fuse box end is slightly different .....its a bespoke fittment ie you have to remove a couple of plastic pegs and hacksaw of a chamfer on the cable end coupling for it to fit!easy enough and its easier than getting that bleedin plastic cover of the newer fusebox Big Cry Big Cry
https://www.defender2.net/forum/topic65541...+box+cover
you have to move the seat heater wire to the ready made whole at the front!
Post #768099 10th Apr 2019 10:31pm
PCM
There is also more info on a previous thread:
https://www.defender2.net/forum/topic66470-45.html
Post #768100 10th Apr 2019 10:36pm
JPE
thanks
Post #768218 11th Apr 2019 9:24pm
