Home > For Sale & Wanted > [Wanted] Ground Anchor |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 430 |
Looking for a Ground Anchor - heavy duty
1st Apr 2019 11:38am |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 531 |
Make your own
1st Apr 2019 7:58pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 |
see the ground anchor plates (GAP) at https://www.defender2.net/forum/topic66623...und+anchor 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
10th Apr 2019 2:43pm |
Is there a particular type you want or have you a particular use in mind?
10th Apr 2019 4:15pm |
The use is to anchor a mobile farm sprinkler to the ground that then reels itself towards the anchor as it turns The pulling force will pull the anchor through the ground if not held securely I have purchased a slightly bent Heavy Duty one from D44 which works well Thanks for the replies |
10th Apr 2019 5:36pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
https://www.bidspotter.co.uk/en-gb/auction...290116de7f
Here you go..... |
10th Apr 2019 9:14pm |
