Home > Maintenance & Modifications > replacing brake calipers
jst
do i go OEM (Delphi) calipers or Britpart. the former being twice the price?
surely calipers are made to a certain std?
i have had quite good experience with the cheaper caliprs (circ £35) in the past 5years on and still good,. these were all Bearmach. my supplier has now gone to Britpart hence the question.
one thought is two sets of Britpart ones would be 10years use and i prob wont be able to afford fossil fuels by then to put in it anyway.... Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #767884 9th Apr 2019 5:26pm
Roy5695
I just opted for a set of stainless pistons and new genuine seals. Nothing wrong with the actual Calipers on mine though. Just a couple sticky pistons. Mr. Green 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #767886 9th Apr 2019 5:31pm
geobloke
Re: replacing brake calipers
From what I was led to believe (by my local parts shop) the majority of "new" brake callipers for Defenders and pre-Disco 3 are in fact reconditioned items so I expect you will be just fine with Britpart callipers.
Take the above as you like, but I have had Britpart callipers on Miffy for four years now and they are still A-OK. Had Britpart drilled and grooved discs on for a good three years as well. All good and Miffy is a heavy beast with her cage on so they get a good workout.
Never had a problem with any Britpart item. Now Bearmach on the other hand, eeeshk does the TD5 in tank pump make a lot of noise... Straight out of the box too... Should have gone with a VDO item... Rolling Eyes
Post #767917 9th Apr 2019 8:08pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I also did that, was amazed how easy it was and still going strong 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #767920 9th Apr 2019 8:18pm
Mdm
come on why would you.......
ill send you some bearmach ones 3yr warranty. fitted plenty and only had 1 faulty set(seals leaked from 1st fit) they just replaced them.
oe ones i think have a better / firmer pedal feel sometimes
Post #767922 9th Apr 2019 8:22pm
jst
Food for thought, Thank you all. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #767932 9th Apr 2019 10:01pm
I really cannot think of any circumstances under which I would consider fitting Britpart calipers to any vehicle of mine.
I accept that many people have good experiences with the brand, I have not, and I do not recall ever having bought a Britpart component which was wholly satisfactory, and some components have been entirely useless (for example hub nut which don't fit the stub axle). I have had unsatisfactory parts from other suppliers, but no other source has managed to supply such a high proportion of duds.
As for a safety-critical part, or a part critical to the reliability of the vehicle, I think Hell would freeze over before I went down the Britpart route.
Post #767940 10th Apr 2019 12:03am
landy andy
Delphi just fitted to mine.
Post #767954 10th Apr 2019 6:58am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
My father had a saying, "You only get what you pay for, if you buy cheap then that's what you get".
You have to remember you rely upon them to stop your vehicle every time you drive it. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #767967 10th Apr 2019 7:59am
Caterham
clearly if you live at the bottom of a very steep hill its not a problem as gravity will stop you on the way up Thumbs Up
Post #768063 10th Apr 2019 7:34pm
williamthedog
^^^But what's going to stop you when you return to your house?
Post #768065 10th Apr 2019 7:40pm
Thon
Specified Zeus to be fitted on mine, together with genuine seals. Zeus are in Dunkeswell so quite convenient for you I would think?
Post #768069 10th Apr 2019 7:47pm
Caterham
oh yes that could be awkward Embarassed
Mr. Green
I'd go for the stainless pistons. being thinking about doing it for ages myself......
Post #768110 11th Apr 2019 5:14am
