Home > V8 > V8 90 not running right on twin SU carbs
ami1971
Any one from around Yorkshire - I need some help with issues I am having with V8, especially with setting up Su carbs- let me know please
Post #767849 9th Apr 2019 2:38pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Sorry but to far away to help. Woreked on SU cards for may years on my Triumphs - 2500tc, spitfires, Dolomite Sprint & 1850, Minis.
Check for induction leak to the butterfly the pivot point which can wear
Ethanol in hippy compliant petrol can cause havoc with the jets and needles make sure they not gummed up and stated to wear
Ethanol fuel also eats away at old fuel line - any fule lines before approx 1999 ish would be an issue
SU carbs otherwise should not give any issues - I assume you know that engine oil should be used in the plunger (sorry to ask this one)
Post #767895 9th Apr 2019 6:22pm
oneten110
What sort of problems are you experiencing? It is not a Defender, it is a One_Ten
Post #767931 9th Apr 2019 9:44pm
