Home > Maintenance & Modifications > Puma 110 fuel tank guard |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
I did on mine (Td5, but similar to puma).
I just welded up a couple of box section spacers to lower the A/R bar down a bit so it cleared the guard. |
9th Apr 2019 5:59am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
You can use tow bar spacers to space off the towball from memory.
9th Apr 2019 7:12am |
9th Apr 2019 7:13am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
IIRC Safari Equip do some anti roll bar spacers for their larger fuel tanks. These are square tubes with a flange welded on at either end. Think it lowers anti roll bar mount by about 3” which is probably excessive for OP use.
Brendan |
9th Apr 2019 7:24am |
Double post, sorry
Brendan |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
It is quite easy to lower the ARB mounts with rudimentary spacers.
9th Apr 2019 10:09am |
Arthur Mak Member Since: 08 Sep 2016 Location: Hong Kong Posts: 11 |
Thank you sirs.
I got it. |
9th Apr 2019 12:59pm |
