![]() | Home > In Car Electronics > A great double din option |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
As aforementioned in order for navigation facility they require your phone to be both charged, and have sufficient data or bandwidth. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
You'll need a DAB splitter (About a tenner) to connect to the standard ariel. Apart from that nope. you're all good. I would however run a rear camera in too, but you don't need to.
For data you can download local google maps (I have) so you don't use data or more iimportantly loose connection. With this smaller form factor head unit you donæt need to mess with switch wires, everything just fits. WARNING, the cut out guide you get with eeh side pannel is way too big. cut it smaller or it will leave a gap or be very wobbbly. You can always increase the size, just not make it smaller. |
