Home > Puma (Tdci) > Ignition Wiring - Help
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
My key wore out resulting in me being unable to turn the engine off, the key came straight out the barrel!!! So stalled the car in sixth gear but the starter then kicked in and span until I disconnected the earth on the battery. Bit of a burning smell so so hope I've not burnt that out.
I've replaced the ignition barrel but now the ignition will not switch on. I've checked the new barrel with a tester and it works ok.
The key fob locks and unlocks the car OK so assuming that it is not an immobiliser problem.
I've double checked all the connections.
Does anyone have any ideas or suggestions? Help appreciated.
Post #766999 5th Apr 2019 11:43am
dorsetsmith
https://www.defender2.net/forum/post561588.html
Post #767002 5th Apr 2019 11:51am
boxoftricks
The red immobiliser light has come one the dash so now wondering as I disconnected the battery how do I resync the immobiliser?
Post #767004 5th Apr 2019 11:55am
Martin
Site Admin
Triple check the connections:
Turn the heater fan on (position 3). Turn the key, does the fan come on?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #767007 5th Apr 2019 12:00pm
Martin
Site Admin
When you say the ignition doesn't come on, do you mean there's no power to the dash etc?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #767008 5th Apr 2019 12:04pm
boxoftricks
Thanks guys. Fixed. Silly mistake on my part
God I love this forum.
Post #767009 5th Apr 2019 12:07pm
Martin
Site Admin
Do tell Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #767010 5th Apr 2019 12:08pm
boxoftricks
When I took the old barrel out it only had three connectors so replicated when replacing. Only to find the forth disconnected itself as connector really loose!
Post #767012 5th Apr 2019 12:17pm
Martin
Site Admin
Before you reassemble everything check the terminals are tight enough on the switch tabs so that they won't fall off in future.
Gently pull each wire to see if you can pull the terminal off the switch. You shouldn't be able to without sliding the plastic coloured terminal cover away from the switch first.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #767013 5th Apr 2019 12:19pm
boxoftricks
Yep done that. It’s where two wires both go into one connector that then slides onto barrel. Unfortunately previous owner was crap at electrics and it’s a big mess with lots of old wires randomly cut behind the dash
Post #767015 5th Apr 2019 12:29pm
Martin
Site Admin
The original harness isn't like that (there's only one wire per terminal) so sounds like there's been some mods there.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #767017 5th Apr 2019 12:31pm
boxoftricks
It’s like everything in life. You spend more time cleaning up other people’s mistakes than it takes to actually get the job done.
Thanks really appreciated your help today. Have a good weekend.
Jeremy
Post #767055 5th Apr 2019 4:44pm
