![]() | Home > Puma (Tdci) > Suspension change - terrafirma shocks and springs |
It's worth replacing all of the mounting hardware (bottom mounts, clamps and shock towers) with galvanised versions for longevity:
![]() Click image to enlarge I'm a big fan of the Gwyn Lewis shock turrets. They're keenly priced and the open design means that mud and grime can't get trapped inside against the shock. Isolators are a good idea, although the solution isn't as straightforward for a 110 as for a 90. The picture above shows all the kit for a 90, which includes Disco 2 front isolators and Disco 1 rears. Unfortunately, the rears won't fit a 110 as the springs are larger. There is an alternative for the rear in the form of isolators intended for a Toyota that are sold by Devon 4x4, although I can't find the link at the moment. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
j17 Member Since: 20 Jan 2019 Location: West Midlands Posts: 59 ![]() ![]() |
Thanks Darren! Will check out Gwyn lewis
