Home > Puma (Tdci) > Broken front axle ?
Page 2 of 2 <12
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I’m not getting much back from Land Rover and I need to get it on the road ASAP
I’ve sent them a second email asking them to clarify their response but nothing back yet !
I want to get my ducks in a row in case they want nothing to do with it
Post #736371 23rd Oct 2018 5:46pm
lohr500
I guess it depends on how much time you have to sort it.
I would have thought a complete swap over with a low mileage 2nd hand axle would be quickest, if you can buy it for the right price. (assuming no change in design and ABS sensor compatibility etc if relevant)
And you could then strip down the original axle at your leisure for spares.
Not sure if the 90 front diffs were the same as 110 which if I recall correctly went from 2 spider gears to 4 at some point along the way. So you may end up with a stronger front diff as well by picking up a later axle.
Post #736372 23rd Oct 2018 5:46pm
Bluericky
I thought I’d post this as Britpart have just added a heavy duty axle casing as a direct replacement for standard. What a shame it wasn’t a few months earlier !
https://www.britpart.com/parts/suspension-...les/da1708 https://www.instagram.com/hustynminepark/
Post #764639 21st Mar 2019 10:38am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Useful to know. Thanks. What option did you go for in the end?
Post #764654 21st Mar 2019 12:33pm
Bluericky
I went for a second hand complete axle , turned out the diff was knackered though so lesson learnt and on reflection I’d have bought new https://www.instagram.com/hustynminepark/
Post #764662 21st Mar 2019 12:50pm
Crikey... how much could go wrong with that Shocked Shocked
Post #764759 21st Mar 2019 10:13pm
dorsetsmith
LRJ had not change manufacturing process for the front axle I.E. the way axle end flanges wald too the main part of the axle just to save penneys
(NOT fit for purpose) LRJ should pay to replace ALL defective Axle
Post #764784 22nd Mar 2019 8:44am
Page 2 of 2 <12
