Home > Puma (Tdci) > BBUS retrofitting
Jimmy B
BBUS retrofitting
I’m thinking about retrofitting a BBUS to my 61 plate puma, has anyone else done this and is any of the required wiring present in the standard loom?
Post #764240 18th Mar 2019 10:37pm
Many people retrofit a BBUS, it helps overcome one well-known vulnerability. A 61-plate vehicle may have one anyway, but if not you won't have the necessary wiring and you'll need the n/s wing harness off a Td5.
Do NOT fit your BBUS in the standard factory location, whatever you do, since this location can be accessed without activating the alarm and the BBUS can then be disabled.
Post #764246 18th Mar 2019 11:51pm
Jimmy B
Thanks for the reply. Am I correct in thinking that if it’s just the wing harness I need then all the wiring is in place as far as the grey multi plug on the bulkhead? If so does anyone know the pin numbers for the BBUS wires in that plug?
Post #764271 19th Mar 2019 10:47am
dorsetsmith
you have pm
Post #764279 19th Mar 2019 11:46am
You are correct, and yes I do. I imagine however that this is what you have already received from Dorsetsmith.
Post #764330 19th Mar 2019 6:15pm
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
Rather than using a new front wing loom you can cut the end off a BBUS relocation loom and get the little spade connectors to wire the relocation loom directly into the blanked off pins in the grey multi plug.
"Sumitomo 090(2.3mm) Male Contact 0.3-1.25mm"
These from automotiveconnectors.com were 16p each and did the trick nicely Thumbs Up
Post #764368 19th Mar 2019 8:31pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Can someone please PM me a good place to relocate the BBUS to?
Post #764426 20th Mar 2019 8:25am
landy andy
And me please.
Post #764547 20th Mar 2019 9:10pm
