Home > Puma (Tdci) > Broken down in France again and now UK.....VERY not happy... |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
Try to take out the main relais undet the right seat and put it in again. This always helped mine start. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
18th Mar 2019 1:49pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2413 |
Yes relays and check battery terminals and grounds. Puma 110" SW
18th Mar 2019 1:53pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3745 |
Starter relay is under seat wiggle them and make sure ok,
Is immobiliser coming off? |
18th Mar 2019 2:22pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Thanks for the replies, wiggled relays under right seat and in fuse box under steering column, still the same, I believe the Immobilier is coming off, the red light extinguished on the dash, still just 4 turns and no fire, then cut out. 2008 TDCi 2.4 XS CSW
18th Mar 2019 2:50pm |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 133 |
Sounds like immobiliser problem - I got recovered a couple of times in my D2 with those symptoms and it started first time when unloaded from the truck
The same D2 also loved France and never wanted to leave - broke down every year for three years; sold it for the Puma in the end. 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
18th Mar 2019 2:53pm |
Can anyone post detailed instructions on how I get to this instrument cluster plug, I am heavily suspecting that, I have no tools, only a leatherman, but I will see if I can buy some tomorrow.. like I say I can’t tether this iPhone connection to my Mac or iPad, iPhone googling and searching is really tricky on a small screen, might se if I can walk to a bar later and get WiFi. 2008 TDCi 2.4 XS CSW
18th Mar 2019 3:08pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
Detailed PM under construction... 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Mar 2019 3:27pm |
Sent 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Mar 2019 3:32pm |
Well guess what, Martins detailed instructions were fantastic and by fate I had a torx set in the cubby box I did not know were there lol......did what Martin recommended, and it started first time, that was a temporary fix with no instrument cluster installed, so I need to find some wire cutters and a small choc a block from somewhere tomorrow.
I am assuming the ferry ramps or cobbled streets in the place we are staying have caused this fault to resurface again, odd it only happens in France lol Martin is a hero and I owe him beers 🍺 Thanks to all who replied. JD 2008 TDCi 2.4 XS CSW |
18th Mar 2019 6:17pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Without going into too much detail, I'm guessing this is now a confirmed immobilizer problem which you've just bypassed behind the cluster?
I like to know these things just in case I find myself or another in a similar circumstance. |
18th Mar 2019 6:39pm |
From what Martin has explained to me, it is not bypassing the immobiliser , but bypassing the Immobilier ‘diversion’ through the cluster. 2008 TDCi 2.4 XS CSW
18th Mar 2019 7:21pm |
Indeed
It does NOT bypass the immobiliser, it just removes the instrument pack from the circuit. The 2.2 are wired like this (no instrument pack in the circuit). 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Mar 2019 7:23pm |
How nice of LR to increase the possible points of failure on an off road vehicle..... 2008 TDCi 2.4 XS CSW
18th Mar 2019 7:44pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1777 |
France is a big place, but just on the off chance where are you?
19th Mar 2019 7:36am |
