Home > Wheels & Tyres > Wheel Clamp as extra security.
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Just wondering if any one is using a Wheel Clamp as extra security.
If so what one would you recommend (or could possibly fit 265/75/16 set up).
It is a sad state of affairs but I am going away for 4 weeks and am concerned following the recent theft attempt of my Defender.
Thanks in advance....... Mr Fu**ed off.... Cheers Don.
Post #763933 17th Mar 2019 9:24am
Swine&Small
Hi Don.
Yes ,I use a Wheel Clamp on mine when I go away. It is a Bulldog Centaur , which is a serious bit of kit. It takes a while to fit but it certainly does the job. Mine fits my 235 x 85 x 16's so I would check out the fit before you buy.
I had mine for my Morgan Roadster so it was a fluke it fitted the Defender. Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #763937 17th Mar 2019 9:36am
landy andy
I have one of these
https://www.bulldogsecure.com/view/bulldog...-clamp/104
And it’s fully adjustable, takes time to initially setup, but easy enough to fit after. It happened to be the same as required for my motorhome.
Post #763938 17th Mar 2019 9:41am
Swine&Small
Yes, that is the one I have, and it also fits my VW camper. Thumbs Up 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #763946 17th Mar 2019 9:59am
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
I have one mainly as a deterrent along with other stuff for when i'm away for the weekend etc I also leave the 2nd gear stick in neutral over night I know it sounds crazy but I do
Post #763955 17th Mar 2019 10:49am
MaxRPM
I use one of the 'London Triangle' commercial size clamps, a seriously heavy duty piece of kit (amongst numerous other security devices).
My Ifor Williams trailer has 4 wheel clamps as well as a heavy duty hitch lock.
Phil
Post #763960 17th Mar 2019 11:12am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Another vote for the Bulldog. I have the CA2500 Centaur. Serious security which for me quickly became easy to fit or remove. I use it daily and don’t find it a chore in light of the protection it provides. The large circular disc that you can see in the photos elsewhere on this thread is backed with a rubber sheet. This will prevent damage being caused to the rim provided you handle the clamp with due care. I can’t deny that the clamp takes up a significant storage space in the back of a 90 if you wish to transport the clamp around.
Post #763980 17th Mar 2019 1:10pm
ericvv
^^ Agree Centaur CA2500 is excellent and heavy piece of protection. Just be careful if installing it on alloys. Risk of damaging the wheel is pretty high. Otherwise nothing than good.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #763985 17th Mar 2019 1:44pm
gilarion
I have a Bulldog wheel clamp, its a huge beast and heavy. It certainly would be hard to remove, however, the fitting of the clamp is not as straightforward as it seems, it is incredibly heavy and I would recommend wearing heavy duty gloves while fitting because if you trap your fingers in the clamp while fitting the arms then a serious amount of skin would be removed. Also as you have to crouch down to fit it and if you have bad knees or back or if the ground is wet you will struggle.
For a long term solution such as leaving the Defender in storage while away it's great but to be honest fitting the lock at night then removing it in the morning (particularly when it is raining) is a bit of a chore and if you carry it around with you in the back the thing is so big it takes a massive amount of space especially in a 90.
As a security device the Bulldog is hard to beat, just be aware that fitting and storing is not as easy as some would suggest.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #763990 17th Mar 2019 2:20pm
I too use a "London triangle".
Post #763999 17th Mar 2019 3:23pm
LR90XS2011
Me too London Triangle fitted when on holiday or when parked at others houses overnight, I also think it looks like an official wheel clamp that clampers use, so sort of changes peoples perception of the car with it fitted DEFENDER 90 TDCI XS,
Post #764001 17th Mar 2019 3:30pm
