Home > Puma (Tdci) > Higher engine oil and fuel consumption?
blimbug
United Kingdom 2009 Defender 110 Puma 2.4 SW Bonatti Grey
Historically between services, my 2009 2.4tdci 110 hardly used any engine oil.
Twice in the past month I’ve had to top the oil up, so it appears to be using more oil.
Also, it “feels” like it’s using more fuel (not confirmed though - I’ve always tried to avoid working out MPG since I don’t want to scare myself).
No engine warning lights and it’s not running badly, so I’m wondering what could possibly contribute to the fuel/oil consumption?
No addition misting on the engine or oil drips under the car either.
Post #763236 13th Mar 2019 6:05pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Blimbug, What is the Km that you have and how much is the consumption?
Post #763357 14th Mar 2019 10:24am
blimbug
It's done 67k miles, was serviced approx 7k miles ago and the oil had dropped about 1 cm on the dip stick (don't know what that equates to in litres - sorry!)
Post #763368 14th Mar 2019 11:15am
rossy
Check out the injector copper washer/seals. Lots of threads on this as it is a very common issue. I had mine done 2 years ago as it started burning a bit of oil. Since they were changed its gone back to burning nothing between services.
Post #764109 18th Mar 2019 8:59am
blimbug
Thanks for the recommendations all.
Off to do some research!
Post #764207 18th Mar 2019 8:47pm
daxdocx
Germany 2010 Defender 110 Puma 2.4 SW Santorini Black
got same problem as rossy, we changed the copper sealings at the bottom of the injectors and it was gone ... be aware the srews are fixed with 6NM at step one and 180 degrees in the 2nd step
Post #766023 29th Mar 2019 10:26pm
Fernando
Blimbug, could you solve the problem of oil consumption?
Regards
Post #788371 23rd Aug 2019 9:39am
