Home > In Car Electronics > Which charger for Odyssey PC1700 AGM battery
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Alongside my other post, I need to charge up my Odyssey battery, and now need a charger.
What would be a recommendation? Some threads suggest CTEK?
Any further thoughts? I Don’t want an enormous cost.
Thanks
Post #763196 13th Mar 2019 1:36pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
The CTEk MXS 5.0 will do the job. CTEKs will generally charge AGM batteries
Post #763209 13th Mar 2019 3:56pm
DC101
Thanks.
Just looking at this on Amazon. At £68, a difference between this and the CTEK MXS7 at over £110. If the 5 is adequate, then perfect.
Post #763220 13th Mar 2019 5:27pm
DC101
Whoops- just checked, and battery is a PC2150 extreme. Presume the same charger will be fine. Will it also tell me if the battery is duff- not holding a charge?
Post #763238 13th Mar 2019 6:15pm
Bluest
The 5 amp should be ok if the battery has little or no drain whilst it is being charged. I have 5 amp smart charger (Aldi special!) that has no problem topping up a 120AH AGM although it's not very quick 2007 110 TDCi Station Wagon XS
Post #763239 13th Mar 2019 6:15pm
kmac
The basic charger won't tell you if the battery is holding its charge or needs replacing. For that you need the CTEK MSX 5.0 Test and Charge
If you have a meter you can check if it is holding it's charge. Actually the basic CTEK has a red and green light on the battery connection which tells you if it has a full charge or needs charging. If it goes red shortly after charging then battery is not holding its charge
Also as Bluest has said, the 5amp will just take longer to charge than the more powerful model
Edit: the red/green light thing is on the panel connector which is an optional accessory - so more money. But I find it useful as you can leave it connected to the battery and just plug charger in when required. Martin of this forum also sells a connector to be able to charge from the towbar electrics (if using 13 pin towbar electrics which has connection to battery)
Post #763345 14th Mar 2019 9:06am
Mdm
sorry to burst your bubble but a cheap charger and a low amp charger isnt what you need for optimum battery performance. if you go on the makers web page there is a fairly good guide to how to obtain optimum life thru charging etc.
we use 10-15 amp on the bigger batteries and 8-10 on the Small red tops and pc1500 pc 1700 we used to run for many years without issue. ctek or a similar quality brand. the ring ones tend to last 12 mths max with regular use.
here is one link for you
https://www.optimabatteries.com/en-us/supp...rging-tips
Post #763513 14th Mar 2019 8:55pm
kmac
From your link...
Low and slow is best. A low amp charger (one to 12 amps) is generally the best choice for charging any lead-acid battery. It's quicker to charge at higher amperage, but it also can generate a lot of heat, which reduces the life of a battery, just like the heat of summer.
Post #763619 15th Mar 2019 2:10pm
