Home > Maintenance & Modifications > SVX style LED 90mm red lense stop/tail lamp
ericvv
Yesterday saw this Twisted 90 here. I like that red lense as in the picture of this Le Perei SVX style stop/tail lamp with its red lense.
Any sponsor here offering those with the correct connector to install on my SVX (replacing the genuine clear lensed lamp)?
If not, where can I buy those best?
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #763011 12th Mar 2019 10:14am
Martin
Site Admin
I have these on my 90 Eric:
Don't believe any sponsors do them, you can find them online under Le Perei part number
SL9LEDSS12V
This is for the red lens version with the Superseal connector (not flyleads).
Edit: they are about £27 inc VAT each - don't pay over the top.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #763013 12th Mar 2019 10:25am
ericvv
Thanks Martin. Will check. The superseal connecter, is that the ones as installed standard on the SVX? So just plug ‘n play on my truck? Asking, because also heard econoseal mentioned here, and I don’t exactly know what is what. And which of those two is then factory used on the SVX style Defenders?
Post #763016 12th Mar 2019 10:34am
Martin
Site Admin
Yes indeed Thumbs Up
The SVX used the Superseal version with an adapter loom from the Econoseal used for the standard lamps.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #763017 12th Mar 2019 10:38am
ericvv
Post #763018 12th Mar 2019 10:56am
Martin
Site Admin
No that is the flylead version with an Econoseal fitted to the wires.
The Superseal version has the socket moulded into the rear of the lamp.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #763019 12th Mar 2019 10:57am
Zed
Post #763021 12th Mar 2019 11:10am
ericvv
Post #763023 12th Mar 2019 11:13am
Sulisuli
Eric if a supplier wont ship to Switzerland, any help having it sent to a UK address then forwarded on from there? if so message me if i can help Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #763059 12th Mar 2019 4:01pm
ericvv
Very kind offer. But let’s first see if that supplier can ship themselves.
Eric
Edit: Just tried to order from my iPhone, but neither my Swiss home address, nor a Belgium address were accepted as shipping address by their website check-out.
So sent them a question to find out if they can and want to ship to one of those non-U.K. addresses. Let’s see if they will answer.
Suli, if they don’t want to, I may take you up on your offer. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #763060 12th Mar 2019 4:06pm
Sulisuli
Happy to help if I can Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #763076 12th Mar 2019 7:21pm
Litch
They are nice lights, I have had a set of eight on the rear of my 90 for nine years now (replacing the conventional NAS lights I fitted back in 2001) and in my opinion they are much nicer than the other LED NAS lights which with the chrome finish look too "blingy".
Seem to recall that at the time it was actually cheaper to buy them from Bearmach as they did pairs cheaper than any Le Perei supplier could, that said Dun-Bri were also very competitive when I last checked their prices.
Being an older vehicle I had to snip the connectors off and replace with bullets.
 ONE LIFE, GET IT!
Post #763096 12th Mar 2019 9:10pm
Hufflepuff
Hello Martin, I would like to order a set of these myself for the 110 rebuild. I am not sure I understand what the difference between these two is though - is the only difference you are talking about here the connector on the back?
I am going to need a new loom anyway.
Cheers,
Chris. 2005 Td5 90 XS
1989 V8 110 CSW
Post #763103 12th Mar 2019 9:43pm
Martin
Site Admin
There are two connection versions: flyleads to bare ended wires or a moulded-in Superseal socket on the back.
You can put Econoseal male connectors on the flylead version and then it plugs straight into the Defender loom. Some sellers supply them like this.
Otherwise you can do as LR did and use the Superseal version and Econoseal to Superseal Adapter looms. These are however outrageously priced from LR and aftermarket for a pair of connectors and some short cables
Shocked
In Eric’s case his SVX already has the adapter looms so the Superseal version are a straight swap for him.
I’ve done a few upgrades with these lamps and I’ve used both versions, although I made my own adapter looms when I used the Superseal version Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #763106 12th Mar 2019 10:02pm
Hufflepuff
Ah right with you now I think. Thanks for the explanation! 2005 Td5 90 XS
1989 V8 110 CSW
Post #763109 12th Mar 2019 10:17pm
