Home > Technical > Front swivel housings - interchangeable?
donmacn
....so many questions, so little time..!
Are front swivel housings interchangeable? Not the swivel balls, but the housings. I have the later ones without the drain plug. Can I use the older ones with filling and drain plugs? Or would I need to change a whole lot of other bits?
Ta Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #762606 8th Mar 2019 9:44pm
grafty99
I would have said they're interchangeable Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #762608 8th Mar 2019 9:51pm
Retroanaconda
The earlier ones won’t be, because they use the raiko bush at the top rather than a bearing.
300Tdi and later housings will fit your swivel balls.
Post #762640 9th Mar 2019 9:17am
dorsetsmith
All none ABS
raiko bush top pin on the left on the right post 1998 on words
Post #762656 9th Mar 2019 11:30am
