Home > Puma (Tdci) > Camshaft Carrier leak |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Mine's had a very slight leak (over the front branch of the exhaust manifold) for at least the last 9 years. It's not bad enough to bother about, but I don't think that it's unusual.
8th Mar 2019 5:13pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
Ahh that’s good to hear that it’s drivable. Do you know if you can just carefully remove the carrier leaving camshaft and everything else in place? Im guesssing I need to tension off the timing chain? Then clean up and reseal?
8th Mar 2019 5:23pm |
I believe the camshafts have to come out before the carrier can be removed from the head.
8th Mar 2019 7:50pm |
