![]() | Home > Puma (Tdci) > Traction light on.. |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 431 ![]() ![]() ![]() |
Sounds like they might have knocked a wheel sensor whilst changing the tyres.
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Did you change to a different size? If so, the speed sensor will have possibly flagged it as an error? 2014 Keswick Utility 2.2
I bet if you changed all of them at the same same it wouldn’t make a difference to the size.
Mev247 Member Since: 21 Feb 2019 Location: Wilts Posts: 49 ![]() ![]() ![]() |
Yes I did change all the wheels to a different size at the same time... So I guess Ive got to zero/cancel the warning light via a diog machine right? 60 110 XS -61k- Corris - For Ever....
It sounds like you'll have to fix the errant sensor, after which the light should reset on its' own. Darren
