Home > In Car Electronics > Double DIN in TD5 dash ? |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Finally got round to fitting mine back in today along with a few other jobs
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
31st Dec 2016 3:51pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
https://www.raptor-engineering.co.uk/produ...ion-panel/ |
21st Apr 2017 10:28am |
It is a raptor dash and I love it lived with it for a while now and one of the best mods I have done 2008 110 2.4 XS Utility (Hagrid)
21st Apr 2017 6:15pm |
Interesting - this could widen the options for my replacement head unit. A couple of questions... Do the existing switches remain in the "old" bezel underneath the Raptor panel? What do the visible screws/bolts fix into?
21st Apr 2017 7:38pm |
The raptor panel fits over top of existing post 2002 td5 dash switches stay in existing holder indash the only thing the raptor panel does is allow to fit a double din
It screw directly to existing dash and you also have to cut lower part of existing dash to fit the d/din unit Mine is a pioneer CarPlay unit and it's superb 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
21st Apr 2017 9:46pm |
BLACK LAB Member Since: 07 Dec 2016 Location: AYRSHIRE Posts: 165 |
Having looked through this .....I can see where the money is in the Raptor one but the Mud stuff looks like a waste of money and cheap - Surely anybody handy could make a better one from 3mm or 4mm or 5mm aluminium sheet the same as the Mud Stuff plate but better .....
Its gave me an idea .......... 2006 DEFENDER 90 TD5 CSW XS 2018 RANGE ROVER SPORT HSE DYNAMIC |
28th Sep 2017 2:54pm |
MaxRPM Member Since: 15 Jan 2013 Location: South Staffs Posts: 1114 |
http://www.ebay.co.uk/itm/7-Touch-Screen-S...1438.l2649
This radio on Ebay is single din fitting and has a screen that comes out and drops down insted of up. This would be more suitable for a TD5 dash installation. |
30th Sep 2017 10:53am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
That would be simpler and easier to fit, but my concerns would be how good would it be and how long would it last being a no name brand.
Do you have enough clearance between the gear stick and the screen when changing gear?I'm currently weighing up a double din for mine with a raptor dash 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
30th Sep 2017 10:59am |
LRDefenderGR Member Since: 29 Jul 2018 Location: Ioannina Posts: 2 |
Hi, I am just about to start working on fitting a double din car play On my Defender TD5 2003 model. What is the depth of your Pioneer CarPlay? |
29th Jul 2018 7:22pm |
BMCrow Member Since: 04 Mar 2019 Location: West sussex Posts: 3 |
@pj2106 I know it was a little while ago but do you remember the double din cage you used? I've bought 2 and neither of them fit. I'm having a bit of a mare with it at the moment. Many thanks
4th Mar 2019 9:48pm |
I used the cage that came with the headunit
Be mindful some cages are slightly larger so you will need to enlarge the hole it fits into From memory the da120 I fitted I had to enlarge the hole on the raptor dash by about 5-8mm as although the unit is standard size the cage was larger I hope this helps? 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
4th Mar 2019 11:13pm |
