Home > Maintenance & Modifications > 2 Post lift and the Defender |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I stick my 130 on a two poster no issues 130's have feeling's as well you know
3rd Mar 2019 10:27pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5740 |
Your Defender weighs a lot less than your Discovery if you are planning on lifting the entire thing at any point
3rd Mar 2019 10:30pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
I've lifted mine (2014 110) many times on a four ton one with no problems.
4th Mar 2019 6:05am |
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 |
Thanks guys. I realise Defender much lighter.
Underneath on the D3 are steel chassis rails giving lots of jacking options. Wondering where to lift the Defender. Is she very front heavy? |
4th Mar 2019 7:03pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
My 90 goes on my ramp regularly for cleaning and servicing.
Front points under the radius arm chassis mounts and the rears on the trailing arm chassis mounts. Steady as a rock Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
4th Mar 2019 7:47pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17467 |
I think you'll find some pretty sturdy chassis rails under your Defender! |
4th Mar 2019 7:57pm |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 |
apachecow wrote:
...Underneath on the D3 are steel chassis rails giving lots of jacking options. ... I think you'll find some pretty sturdy chassis rails under your Defender! .....unless the rustworm has bitten. Not so sturdy then. To be fair, as far as I know, mine are fine. (Tempting fate). I guess it's usually the rear cross member and the outriggers that go first. How come RRC chassis never had the same problem? Pretty much surface rust only with them wasn't it? |
6th Mar 2019 5:21pm |
