Home > Maintenance & Modifications > Brake Servo 2.2
AndrewS
Brake Servo 2.2
After a bit of advice, the brake pedal on my rarely used 130 seems very stiff. I'm wondering if there could be a fault with the vacuum pump. Then I thought oo hang on does the 2.2 have a vacuum pump? Can anyone advise? 130's have feeling's as well you know Smile
Post #761765 3rd Mar 2019 8:46pm
As far as I know the 2.2 has a mechanical vac pump driven off the rear end of the offside camshaft (so quite different to the 2.4).
Part no LR029681.
Post #761792 3rd Mar 2019 11:33pm
AndrewS
Bow down Thumbs Up has anyone suffered issues with it? 130's have feeling's as well you know Smile
Post #761939 4th Mar 2019 10:04pm
jst
Is there no limited vacuum or is the servo not holding it? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #761941 4th Mar 2019 10:09pm
AndrewS
It's got Bowler brakes front and rear. One has to properly stand on the pedal to get the thing to stop. Just wondering if there is an issue with the servo or perhaps the servo just isn't man enough to operate the brakes to their full potential. The Bowler brakes have been fitted for a few years. I'm running around in a standard 110 and the brakes are a lot better. 130's have feeling's as well you know Smile
Post #761960 4th Mar 2019 11:50pm
landy andy
I assume you’ve done the standard servo test?
Press brake pedal numerous times till hard pedal achieved, then start engine and see if pedal drops. You can also just pull vac pipe out of servo whist engine is running. That will tell you if pump is working.
Post #761963 5th Mar 2019 12:03am
jst
Pull the vac pump hose off the servo. Engine off. Is there a hiss as hose is released? If yes how does it compare doing same on the std 110?
With engine running, is there vac at the end if the servo hose? Enough to make finger go red!
Sounds like either resistance in system or not enough initial assistance.
I suspect either sticking pistons or faulty servo.
This is presuming it's been ok since upgrade 2yrs ago? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #761981 5th Mar 2019 8:58am
AndrewS
Thanks for your replies Thumbs Up You have given me plenty to look into Bow down 130's have feeling's as well you know Smile
Post #762778 10th Mar 2019 1:06pm
AndrewS
Servo is working ok, I'm having to replace the rear pads as the are properly worn, fronts are ok. The fronts are the same age as the rears I find it strange that the the rears have worn out before the fronts Rolling Eyes 130's have feeling's as well you know Smile
Post #769527 21st Apr 2019 10:17pm
UtilityTruck
My def seems to wear out rear pads before fronts too. Extra weight at the back vs a front drive hatch means the backs are working harder. 2014 Keswick Utility 2.2
Post #769548 22nd Apr 2019 7:17am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Same here with the rear pads. My MoT advised they were getting low a few weeks back so I decided to swap both front and rear to be safe. The fronts would have lasted another 10,000 miles easily (painful for someone as 'fiscally aware' as me...) but the rears were nearly gone.
Post #769550 22nd Apr 2019 7:36am
AndrewS
You would have thought that with weight transfer and the bias sending the brake force to the front, the fronts would wear out sooner. Perhaps the rears being smaller causes them to wear quicker. 130's have feeling's as well you know Smile
Post #769554 22nd Apr 2019 8:03am
UtilityTruck
Yep, I think the smaller pads also play a part.
What with the engine being up front it’s tempting to think the back doesn’t do much, but of course there is still a heavy driven axle back there, plus the spare wheel and if you have a rack a big component of that weight will be on the rear axle too. Which reminds me I should check my pads again... 2014 Keswick Utility 2.2
Post #769578 22nd Apr 2019 12:18pm
Retroanaconda
The rear brakes also get all the dirt and grit in road spray which the fronts don’t see as much of. The difference in the rate of wear is much worse if you regularly use unsurfaced roads, and doubly so if you’ve removed the rear brake mud shields.
Post #769594 22nd Apr 2019 3:03pm
AndrewS
Turned out to be the servo suspected pin hole, new one fitted and a vast improvement. 130's have feeling's as well you know Smile
Post #781697 16th Jul 2019 3:04pm
