Home > Maintenance & Modifications > Missing door seal
Page 2 of 2 <12
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Sometime in the last six months I saw a replacement seal for the bottom of the door, I have tried looking on internet and I cannot find it. The foam was bonded to a stainless angle, the angel had a number of holes in it, the purchaser needed to drill the bottom of the door and insert plastic clips. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #761510 2nd Mar 2019 10:33am
cold
You may find this useful? Post fit of newer door seals.
http://defender90xs.blogspot.com/2014/08/u...seals.html
Post #761511 2nd Mar 2019 10:41am
j17
Thanks for all the help
I have checked this morning and only the passenger door is missing the door seal and the foam insert - not sure why??? but I will get the parts ordered this week
Post #761522 2nd Mar 2019 12:54pm
donmacn
LandRoverAnorak wrote:
donmacn wrote:
Do these improved door seals fit on earlier doors? The TDI ones, or the newer 'round corners' galvanised ones?
Unfortunately not. The door frames are very different shapes.
Not picking a fight! Just wondered what we might collectively think of this:
I've just put new, genuine lower seals on my new doors, and there is clearly a couple of inches on either end that isn't covered/sealed. I could use some foam blocks - I think that's what's supposed to be there - but I'm still tempted by using these bigger seals.
This lad has done it with just a couple of extra holes on the sides of the doors. It does look from some of the photos that the seals might be a little proud on the sides of the doors, but other than that, seems to work OK? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #772529 10th May 2019 6:41pm
Ok, I'll revise my answer to 'not without a degree of faffing around and even then not very well' Laughing Darren
Post #772532 10th May 2019 6:56pm
donmacn
Thumbs Up Fair enough!
I am tempted though. Not just because of the bits that come up the sides, but also because the bit along the bottom of the door seems more substantial than what's basically a bit of rubber with a 90' bend in it! Donald
in the past..
Post #772534 10th May 2019 7:23pm
Page 2 of 2 <12
