Home > Puma (Tdci) > Winch options
22900013A
Winch options
It is becoming clear that in my line of work a winch is going to come in very handy - not for off-roading obviously, but for loading my trailer. I am thinking of getting a winch but not sure what the best route to take. I could mount an electric one on the trailer, but this could upset the balance of the trailer, and will reduce the payload slightly - I understand a winch can be upto 50-60KG? I'd run a lead and socket from the 110 to power the winch rather then use a separate battery.
The other option is to mount one on the 110, I was thinking a front mounted one could be used, with a towball on the front to hold the trailer - BUT that would be a lot of hassle (and lost time when its all against the clock/tacho), is there any kind of mounting available for the back? Right now I'm struggling to accept jobs on vehicles that won't drive...
Any help much appreciated. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #76099 15th Jun 2011 8:53pm
mick
What sort of trailer is it a customer of mine has an Ifor car trailer with a husky winch on the front and conects it with Anderson plugs.
Post #76105 15th Jun 2011 9:17pm
noworries4x4
Ive got a warn 9000 on the front and tow ball as you sugessted, turning round does not take as long as you may think, but for quick light loads i use a hand winch quick easy and a good bit of blood pumping excersise. mine is not a bolted down one its a mule hook on to the front and 1 line 900Kgs 2line 1800kgs and really quick, even more handy for you in Bicester i got both the winch cw bumper and the hand mule from Sling and tackle Milton Keynes if memory serves me correctly 3rd Avenue near the big Asda/Walmart, B&Q and Tesco If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #76115 15th Jun 2011 10:05pm
JSG
How about one of those demountable winches that hook over a towball? You could fit a towball to the trailer and connect it via anderson connectors. John
2011 Tdci 110 CSW XS
Post #76127 15th Jun 2011 10:38pm
Firstly make sure the trailer can take a winch ie mount safely oh also make sure to get some training if you have not used a winch before.
Seen some real horrors in the past, don't be tempted to go the synthetic route as a trailer type of recovery lends it self to a steel cable (loads of drag and catch points)
Post #76149 16th Jun 2011 1:54am
mowcop
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I had a bateson triaxle with a hand winch fitted but had a 8274 on the front of the 110.
I found this covered most problems, if the vehicle was dead but easy to get to I would use the trailer hand winch (very light at about 15KG max) if the vehicle was on a bad feild, in a shed or other nightmare position I would un-hook the trailer and use the 8274, sitting in the vehicle to steer it and using the wireless remote.
This set up never let me down.
When I brought the trailer new I asked about the electric winch but the guy pointed out if you go on a job and the batterys flat or the winch plays up your stuck, the hand winch will always work!
Post #76188 16th Jun 2011 10:56am
22900013A
Were I to go for a leccy winch Id have a power lead direct from the Landrover.
I'm not so worried about turning the 110 around, more the faff of having to re-hitch the thing, its not so easy in a USW as you can't really see where the hitch is. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #76610 19th Jun 2011 9:43am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Might have a genuine land rover warn winch and bumper available, purchased january this year, pic of it in my gallery, no idea of price yet though, someone already trying to get me to sell to them but have not agreed price or sale
Post #76644 19th Jun 2011 12:27pm
Zagato
Hitching difficulties Neutral Big Fog showed me his rear camera the other day - great bit of kit VERY wide angle shows the rear lights and cars behind all in one shot very reasonably priced piece of kit for a TV screen, monitor etc think it was £110 - I want one, better than reversing sensors and as Big Fog says you won't reverse over your kids which is always a risk with my two dippy dipsticks! Rolling Eyes Or get a bumper camera for £90 just googled one Thumbs Up
Post #76681 19th Jun 2011 5:25pm
