Home > Maintenance & Modifications > Who has a 110 with Bilstein B6 and OEM springs.
Stacey007
Hello
My 110 is the longest car I have owned now and the millage creeping up. I feel it's time to change some bits.
- Bilstein B6 Shocks
- OEM Springs (apparently more comfy than Alive comfort or others)
- PolyBush Kit
- Uprated rear anti roll bar.
So with the above kit I am hoping to make my Truck feels 'tighter' / newer but without making it even harder ride....
Has anyone done similar what do you think?
Post #761352 1st Mar 2019 1:59pm
JOW240725
That's the setup IRB Developments say they recommend and fit most often. It's on my wish list. I'm just not sure if to go polybushes or original as a lot say the former are too harsh.
I also quite like the idea of fitting spring isolator but want to keep standard height. Thumbs Up
Will be following too with interest. Thumbs Up James
Instagram @suffolk_rovers
Post #761357 1st Mar 2019 2:44pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I thought IRB use the OME shocks more than the Bilsteins, I hear a lot of people say they find them harder than standard Confused
I'm looking into making the ride less harsh as well but there's so much conflicting information out there it's difficult to know what's best...
Post #761362 1st Mar 2019 2:49pm
LR Sam
I have that set up but in my 90 and standard rear anti roll bar - personally I feel the set up is harder that original but it certainly makes it handle better. It drives very well but is harder over small undulations. You could always go soft superpro kit to help further.
No matter what you do, I would certainly be tempted to do the steering damper to Bilstein as this on its own made a world of difference to the steering especially when hitting potholes etc.
Post #761365 1st Mar 2019 2:52pm
JOW240725
To quote Ian Baughan from 2016 "Personally I'd go for the Bilstein B6 dampers, genuine LR Defender springs, an uprated rear anti roll bar (25mm) and a standard front anti roll bar. Both anti roll bars mounted with Superpro bushes.
I've used this set up a lot and is a great all round package.
Lowered springs done badly are too hard, and a softer set up gives a nice ride, but limits load carrying. I have had progressive rear springs made, but still ends up getting a bit low when on the stiffer part of the spring."
Embarassed James
Post #761367 1st Mar 2019 2:54pm
X4CAC
Your so old skool James 2016 Laughing
Post #761368 1st Mar 2019 2:58pm
JOW240725
Yes I must admit I was surprised it was that long ago when I looked!! Embarassed Maybe I do need to update my ideas! James
Post #761370 1st Mar 2019 3:02pm
Zed
Embarassed
After trying out various setups the above was what worked best for me. Only with genuine bushes instead. i also have the Bilstein steering damper but I don't think it made any difference, good or bad. If I was to do it again I wouldn't bother with that. The only handling modification I intend to add now is the Bowler quick ratio steering box.
i wish I had seen that info from IRB at the time, it would have saved me a bundle.
Post #761516 2nd Mar 2019 12:42pm
Caterham
guilty.
IRB did as above (Bilstiens on original springs and poly bushes (possibly pro bushes not quite sure)) and I've had no reason to consider changing since.
the dampers simply make it all a little bit more controlled. it makes the originals feel like they were a bit worn out. Thumbs Up
I seem to recall the anti roll bar upgrade was loosely recommended too but I haven't gone down that route.
Post #761521 2nd Mar 2019 1:47pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I’ve got that set up on my 110 DCPU and it’s made a huge difference to overall handling, it feels more precise and cornering is hugely improved . I have also fitted the standard Britpart bush Kit which has let it down a bit as they’re really too soft .
The Bilsteins have made the ride a little harsher over the potholes but not at all unpleasant and certainly a worthwhile upgrade . I didn’t bother with upgrading the steering damper as read a lot of conflicting opinions so just bought an OEM Armstrong one.
My front springs are new standard OEM but the rear I downgraded to the softer 110 station wagon part number giving a softer ride. I believe the double cabs and 110 vans have HD fitted as standard. https://www.instagram.com/hustynminepark/
Post #761553 2nd Mar 2019 6:31pm
Caterham
/\ good point re; the steering damper.
I did go for the Bilstien damper there too. It's a while ago no and my memory isn't the best. I seem to recall the only notable difference was it tends a go back to centre a little more accurately with a little more conviction but again not a game changer just takes helps take away some of the 'slack'.
as noted above it all just feels a little tighter. more car like.
Post #761555 2nd Mar 2019 6:40pm
Stacey007
Thanks
I already have an uprated steering damper a tearafirma one? that's less than a year old
So far I have been advised to keep the springs and change to the B6's
Post #761558 2nd Mar 2019 7:13pm
Bluericky
This is a very informative video that’s been shared on here before . If you’re deciding whether to upgrade your steering damper it may sway you to do otherwise!
Post #761559 2nd Mar 2019 7:18pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
have had this set up on my 110 sw. for a few years now. and it still amazes me how well it corners. (for a defender)
nice combination i think. 110 xs s/wagon
s3 swb soft top
Post #761561 2nd Mar 2019 7:48pm
Grenadier
Just had my B6 kit delivered last week. Will fit with standard shocks on my 110 DCPU. I’m staying with standard bushes as many on here say they’re good enough. Will give feedback when done. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #761564 2nd Mar 2019 8:17pm
