Home > Technical > Drive Train Slack
Grenadier
Drive Train Slack
Morning all,
Noticed a lot more drive train slack when pulling away in 1st or in reverse. Requires a lot of feathering of the clutch to avoid a huge clunk, audible middle to rear of the vehicle. I had the clutch replaced six months ago, although I've never been happy with it as it is noisier, more rattly, the gear selection clunkier and more difficult, and there has always been a little slack from the get go. Originally the gearbox and clutch were perfect. Very smooth, very quiet. The clutch was fitted whilst the vehicle was broken down abroad, OE fitting, by a LR dealer in Spain. So as I wasn't there I can only presume it was done properly and with an OE part as stated.
So I can I check what the clunk is and where the slack is located. Clearly I'm thinking half shafts, but should I be checking for anything else?
Thanks in advance Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #761309 1st Mar 2019 7:09am
WindyJ
Checking the HS is easy so if it’s that you’ll know but if not them and the clunk comes from the center of the vehicle it may mean an opportunity to convince yourself you need an Ashcroft center ATB.
Post #761329 1st Mar 2019 10:42am
rallysteve
Have a good check/pry of the A-frame balljoint! 02' 110 TD5 Double Cab Rebuild Thread
Post #761344 1st Mar 2019 12:15pm
DG123
Was output shaft on mine - same symptoms Sad 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #761356 1st Mar 2019 1:37pm
Check the easiest cheapest things first is what I'd recommend. Then go upwards in value abd work from there so to speak. Thumbs Up $W33T $0U7H3RN $UG4R
Post #761371 1st Mar 2019 2:03pm
JOW240725
When I read this my first thought output shaft. I was surprised how much slack disappeared when I had mine replaced. James
Instagram @suffolk_rovers
Post #761372 1st Mar 2019 2:04pm
Bongo1
Had this with mine and changed the A frame , Turned out to be the rear prop UJ was as stiff as ducks @@@@ , once it was off . Looked and felt fine .
Post #761473 1st Mar 2019 11:53pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
If the symptoms have come on fairly rapidly then I would take a long look at your diffs as well as half shafts , flanges etc
It was the huge slack in my drivetrain that was the precursor to diff failure . Once it was replaced nearly all play has gone and no more riding the clutch !!! https://www.instagram.com/hustynminepark/
Post #761477 2nd Mar 2019 1:10am
Grenadier
Thank you all, will try and figure it out next week... Thumbs Up Monsieur Le Grenadier
Post #761566 2nd Mar 2019 7:22pm
Grenadier
Quick one, how do I test diff slack/wear? Twist the prop and see how much play there is before biting? If so, how much play should there be, by degrees or mm? Monsieur Le Grenadier
Post #761574 2nd Mar 2019 7:37pm
Caterham
am I the only optimistic one here?
check rear drive flanges Mr. Green
Post #761576 2nd Mar 2019 7:39pm
Grenadier
Will do that as well Caterham. I drive daily and negotiate a huge number of bends/hairpins, which on reading up seems to stress flanges/half shafts. Easy fix, so hoping its the cause. Monsieur Le Grenadier
Post #761582 2nd Mar 2019 7:53pm
Bongo1 - Yes, same here but prop in situ all UJ's seemed fine when checked. It was only once off I could tell a single UJ had completely failed and the UJ spider arm was loos in the bearing cup and the roller bearings were mashed to dust non existent.
The rest were fine.
All seemed okay in situ but once the prop was removed it was evidently clear.
It seems to the the UJ's to the rear diff that are often the culprits and often on an 90. $W33T $0U7H3RN $UG4R
Post #761583 2nd Mar 2019 8:12pm
Grenadier
Video
Noise is getting worse, so I took a video of the slack/play I have between T-box and Diff. There is little or no sound when slack has been picked up, gear engaged and in drive, but there is a distinct rattle the moment I clutch or disengage drive but the shaft is still turning. T-box, Diff, UJ?
Post #763159 13th Mar 2019 10:43am
MK
Actuaĺly you would need to remove the propshaft to asses the cause of the slack. Puma 110" SW
Post #763162 13th Mar 2019 11:09am
