Home > Maintenance & Modifications > Rear Wheel Box Storage!
Zagato
I'm thinking about making some storage boxes similar to the ones I have in my 109. They are cavernous and would be so useful to store stuff! Just wondered if anyone has done this before or seen any on the market already to go? The rear seats will block much of the opening but there is still a good gap to load up the box Thumbs Up
They are 2' long by 1' wide and 9" deep. Makes me wonder why they don't put them in anymore Sad
Post #76107 15th Jun 2011 8:26pm
Happyoldgit
Cost cutting is probably the reason plus the top of the wheelboxes are no longer flat. You can get lockers that access from the side but it wouldn't be difficult to fabricate some top access versions up.
TBH I'm not sure I can envisage you cutting and hacking your precious baby about to that extent Wink Steve.
http://forums.lr4x4.com
Post #76111 15th Jun 2011 8:49pm
WarPig
Barebox sell them. He was on this forum a few months ago asking for dimensions for the puma. Ill find his contact details for you if you give me a minute...
Post #76121 15th Jun 2011 9:31pm
Zagato
Thumbs Up
Post #76124 15th Jun 2011 9:34pm
WarPig
Ok, not quite the same, his boxes stand on top of the inner wheel arch. Im sure he does them for pumas..
http://www.barebox.co.uk/
Post #76126 15th Jun 2011 9:38pm
I have been thinking about a storage box. I like the idea of using the space at the rear of the wheel arch but having a door on the outside is silly so how about having the door inside next to the 3rd row seats?
I did email entreq but did not get a reply.
if you have to cut the rear wing to install the existing offerings then cutting the wheel arch inside the tub should be a much easier option ..
Post #76129 15th Jun 2011 9:40pm
VeeTee
Netherlands
What about this? Today i made this storage solution: a square PE plastic container inside the wheel arche. It is about 25 x 25 x 35 cm with large diameter opening, approx. 20 l volume.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #76132 15th Jun 2011 9:44pm
Zagato
Thanks Warpig, might be able to do something with one of those - I think the price is reasonable also compared with a lot of the overpriced stuff Thumbs Up
Vee Tee.........Genius! Wink
Post #76157 16th Jun 2011 6:43am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
and the tyre is going to rub on that bottle? or not ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #76197 16th Jun 2011 11:00am
VeeTee
Netherlands
No, may be it is not very clear to see in that picture, but there's lots of space. Cheers, Vincent
MySite
Post #76201 16th Jun 2011 11:30am
Zagato
Change of plan I am going to take the rear seat out and put a storage box in it's place with an unseen safe going into the side of the wheel box.
Barebox http://www.barebox.co.uk/ seem to be the only people that are working on a chest that fits the Puma curved wheel box shape! Does anyone know of one already on the market? The barebox does look good and decently priced compared to the Mobile storage System one at £192 + VAT Shocked No one seems to do one specifically for the Puma yet...
Post #77166 22nd Jun 2011 6:53pm
spudfan
Ireland
If you have someone near you who makes iron gates and railings etc get them to make something to your specs. out of light metal sheeting on a metal framework. Would not cost much and it would be made to fit your vehicle. Quite easily done in this neck of the woods. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #77171 22nd Jun 2011 7:10pm
Zagato
It's a thought Thumbs Up Labour charges are £40 an hour around here plus materials would be the price of the £80 box. I don't think they could do it for 1.5 hrs say - worth a try though. I should have a go myself but it would be better to get it done professionally as it will be very visible and it would take me best part of a day to do it myself so might as well earn it to buy a proper job!
Post #77195 22nd Jun 2011 7:59pm
Zagato
Steve at Barebox was very helpful and sent through a CAD drawing immediatley so I could find out if it fitted and it would apart from the thicker window moulding present on the Puma Banging Head You could put a reverse lid on it and cut around the moulding but it would lose it's rigidity Sad
Back to getting one adapted or having one built bespoke or making the sides and front from wood covered with black carpet/vinyl with a chequer plate top. You only need a front, top and sides if you line the inner wing to protect it OR a wood frame with chequer plate sides, front etc! Thumbs Up
The Mobile Storage Systems one that was designed for the old Defender does fit if you turn it on its side but you lose all of that space under the recess.
Post #77246 23rd Jun 2011 8:57am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I'll be going over to Mobile Storage Solutions later this month and one thing i'm going to do is go through a design for a box that fits the contours of the wheel arch in my DCPU. I'll keep you posted. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #77253 23rd Jun 2011 9:57am
