Home > Td5 > Defender Low range ECU map |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4793 |
Is it worth having the ECU remapped with a standard tune? 2002 90 Td5 Station Wagon
27th Feb 2019 8:01pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2909 |
That’s been done. The remap works well but it still defaults into the softer response if you floor it.
It seems to be pedal position, rather than actual engine power. So you can use all the power and as long as you don’t press the pedal right down it stays in the more responsive mode. |
27th Feb 2019 8:23pm |
The only things left to try, then, are pedal to ECU loom or the ECU itself 2002 90 Td5 Station Wagon
27th Feb 2019 8:30pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
I assume you can rewrite a low range map?
If you can, could you just copy the high range onto low. Tha way it wouldn’t matter if it changed high to low? Just a thought. |
27th Feb 2019 8:50pm |
Well yes that’s a thought, although then you would still have the high range map when you were actually operating in low range, not ideal, particularly with a remap.
27th Feb 2019 9:25pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Have you tried unplugged the maf?
As said there is no high and low map. Just adjusts the throttle response but that can be adjusted via mapping as well. This sounds more like overboost, ideally you need to plug in diagnostic.to see what is happening and why. My guess would be the ECU is reading too much air and cutting the fuel temporarily. This can happen without showing an EML Instagram @defender_ventures Empire Tuning - Agent |
28th Feb 2019 5:43am |
Ah l finally understand
No “low range map” just a change in the way the pedal operates. |
28th Feb 2019 8:28am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 |
the easiest way to find out if this is really the issue is to put a stock map back onto the ECU and try it.
Assuming you still can read what's written on the sticker on the ECU, you can get hold of that same map and load it on the ECU and then do the test. or you can borrow a known good working ECU and make it learn the security code from your 10AS (or it won't start) and give that a try. remember that you will need to make that borrowed ECU relearn the security code of the original vehicle after that. however, if the ECU was not original, then something must have been messed up. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
1st Mar 2019 2:15am |
I had the ECU reset at Land Rover and it made no difference. Our 2006 TD5 90 did it too, software issue if you ask me.
I’ve done 100,000 miles in the two Defenders with this “fault” and pretty much resigned myself to never sorting it. Bring back my 1988 300TDi !! |
2nd Mar 2019 6:33pm |
How frustrating. So you have swapped the pedal, have you checked over the wiring from the pedal to the ECU - Loose connection or possibly intermittent break in a wire? I have a reoccurring driver demand fault (3/5) on my TD5, literally driving me crazy so I understand entirely. Interesting that it could be an error in the map code... That I will have to explore a little more as mine has been mapped and didn't do it before the map... |
3rd Mar 2019 11:15am |
