confused - Glow plug timer/ starter relay and Crank
Hi Defender net,
I am rewiring my TDI300 pre- ECU defender as the there are a few additions as the old wiring we a nightmare. Looking at the primary circuit (start and charge).
the question is around Crank (rd/Wh) connection - I am told the crank needs to be connected to the starter relay (ok that makes sense) as well as the timer solenoid. ( when the ignition is turned on the glow plugs heat, when the crank turns .....eh... what) I thought the crank would stop the timer to allow more power to the cranking. I am advised it also should energise the glow plug timer as well as it cranks....??????)
Equally when wired as per the diagram below the crank is live .....without turning the key - a little lost here?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
