Home > Maintenance & Modifications > Rear Indicator Lights condensation
Alexke
Belgium
Hi There!
I Drive a TD4 Defender and I replace my yellow indicators with clear one`s
Now each 3-4 months I get condensation and dirt in the housing . very annoying!
I Have found the cause : its some sort of mud buildup in my rear wheel well!
The dealer already needed to replace the cable and connector because it was damaged by corrosion.
Has anyone got a solution for this problem?
thanks in advance!
Pics will follow !! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #75969 15th Jun 2011 12:21pm
Zagato
The rear splash plates are pretty useless for water, mud ingress but do what they are designed to do which is to stop stones etc damaging anything. One of my next jobs was to improve the coverage of these somehow. In standard form they have a 2 inch gap where all the water and crud just gets blasted up the inside of the rear quarter panel Rolling Eyes Wouldn't take much to rectify - someone has already done it on here, hopefully they will come along so I can patent it Very Happy ...
Post #75988 15th Jun 2011 1:10pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I noticed this too, but what I also noticed, as I have clear lamps from two different manufacturers, is that the Wipac ones condensate but the LE Perei ones don't.
On mine, on both types the clear lens is bonded to to the rear moulding. On the Wipac ones, if you look through the screw mounting holes, the clear part doesn't quite line up with the rear part, whereas with the Perei parts the two halves line up perfectly.
I put it down to this misalignment creating a small void between the parts letting the water in via the screw holes. I fitted small plaastic washers under the screw heads on the Wipac units and it has improved it slightly, but not eliminated it completely. I think I need to find some slighly larger washers made from slightly softer nylon so that they can more easily deform to take the shape of the holes.
(Man, that looks anal now I read it back!)
Pete
Post #76008 15th Jun 2011 2:31pm
Grockle
smear vasaline around the bulb holer to the lamp,this will stop it 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #76012 15th Jun 2011 2:41pm
Happyoldgit
Yep, I was going to suggest taking them out, thoroughly dry them off and then seal them up when refitting. Steve.
http://forums.lr4x4.com
Post #76019 15th Jun 2011 4:06pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
I too have had this problem with WIPAC replacement lights, both red and clear ones. I put it down to the fact they cost £2.99 rather than about £15 like the proper Land Rover ones Confused
I had tried putting vaseline/sealant round the bulb holder, but the condensation persists so that's clearly not the problem. Looks like it may be the screw holes as said above. I'd have thought squirting a dab of sealant down the hole before inserting the screw might cure it?
Or just cough up for decent parts.... Big Cry
Post #85553 22nd Aug 2011 8:54am
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
I have the same problem with the wipac, funny the supplier said he has never heard of this problem !!!!!!!!!
Post #85555 22nd Aug 2011 9:11am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Grockle is right the only thing that works Thumbs Up : NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #85589 22nd Aug 2011 5:26pm
