Home > Maintenance & Modifications > Work Light with Reversing light and overide switch
x-isle
Just thinking out loud here......
I'm going to put a work light on but then thought about taking a few steps further.......
I want to be able to have an on/off switch wired directly to the battery so that it can be activated without ignition.
I also want it to come on when reversing in the dark.
So, both are pretty easy, the switch is, well, just a switch, a 2 way toggle switch at that.
I'll attach a relay to the tail light feed that will switch power on (from the reversing light) to the work light when the headlights are turned on. So only when both the Tail light and the reversing light is on.
My only concern is the power draw (55W in the Work light) from the reversing light circuit.
Any thoughts? Anyone actually done this? Is it legal?
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #75964 15th Jun 2011 11:57am
Zagato
I was looking at a G4 Freelander the other day and apparently all the interior switches for the front and rear roof mounted spotlights were removed before it went on the market as it's illegal to be able to switch on some of these lights whilst driving Confused The switches have to be located away from the driver apparently, not sure if that is correct info!
Post #75977 15th Jun 2011 1:01pm
x-isle
Yeah, I know about that rule, but I'd put the override switch in the back so that it couldn't be switched on when driving.
Just out of interest, how do you then switch the rear light on if there is now switch? Craig Rogers
2007 Puma 110 XS
Post #75979 15th Jun 2011 1:03pm
JSG
Tombraiders were supplied with the relay missing for the roof mounted spots for the same reason. You got a relay with them that you could plug in yourself if you wanted to be naughty Rolling with laughter John
2011 Tdci 110 CSW XS
Post #75985 15th Jun 2011 1:08pm
x-isle
Hang on, so are we also saying that all rear work lights are in fact illegal as far as the MOT is concerned? Craig Rogers
2007 Puma 110 XS
Post #75989 15th Jun 2011 1:22pm
Martin
Site Admin
The reverse lamp is wired with 0.75mm^2 cable (14A rated), and fused at 10A (Fuse 14).
The work light 55W lamp at 12V is drawing ~4.6A
The reversing 21W lamp at 12V is drawing 1.75A
So a total of 6.35A, which is comfortably below the rating of the cable or fuse, so you would be OK.
However, as you are already running a battery feed to the two way switch I would add another relay in and remove the additional work lamp load from the reversing circuit.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #75994 15th Jun 2011 1:36pm
x-isle
Now that's an answer! Thumbs Up Biggo Thanko!
So you mean something like this (the only thing missing is an extra fuse after the battery);
 Craig Rogers
2007 Puma 110 XS
Post #75999 15th Jun 2011 1:57pm
Martin
Site Admin
Yep, or you could move the toggle switch to swap between the output of the first relay and a permanent 12V on the input to the second relay; this means you only have one set of contacts doing power switching (in the second relay) and less wiring to run.
Something like this:
Don't forget fuses though! Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #76010 15th Jun 2011 2:36pm
x-isle
Ah, yeah, even cleaner, plus the main draw isn't going through the toggle switch either!
Mucho Graz! Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #76011 15th Jun 2011 2:39pm
x-isle
Yeah, I've got a small 4 way fuse box, so I was going to go a bit overkill and use it.
I'll have the following fuses
1: Before 86 on Relay 1 (feed from Sidelight) - 1Amp
2: Before 30 on Relay 1 (feed from Reversing Light) - 1Amp
3: Before 2 Way switch coming from 87 on Relay 1 - 5Amp
4: Before joint coming from battery, feeding 2 Way switch and 30 on Relay 2 - 15Amp
A bit over kill, but as there are 4 slots to fill....... Mr. Green Craig Rogers
2007 Puma 110 XS
Post #76032 15th Jun 2011 4:44pm
mse
Just a point roof spot lights are perfectly legal on the main beam, switch and illuminated
Fogs on the roof are illegal
Work light perfectly legal - but not used on the road switched with reverse Mike
Post #76034 15th Jun 2011 4:49pm
x-isle
Hmmm, good job I've decided on a 3 position switch! Mr. Green
Position 1: Work Light off
Position 2: Work Light on when Reverse and Side lights on
Position 3: Work Light on Craig Rogers
2007 Puma 110 XS
Post #76039 15th Jun 2011 4:52pm
Glynparry25
Shocked Shocked Shocked Talk about complicating things!
We have a saying in the Army 'KISS'.... Keep It Simple Stoopid.
I understand that at night you would like it to activate when you select reverse....... but for simplicity, why not have it so that it engages every time you select reverse (not like you spend hours on end in reverse).
Adding 2x relays is un-necessary, unless you plan on using a high power work lamp (More than 50W). It is just more to go wrong- it is always easy to get carried away with complicated circuits.
Glyn Dog Sheep
Post #76041 15th Jun 2011 4:56pm
ARMYBOB
United Kingdom 2001 Defender 110 Td5 CSW Java Black
you sound like a tiffy glyn! Laughing
i agree KISS all the way, one switch one relay, when you are reversing just switch it on for more light! simples
Post #76045 15th Jun 2011 5:03pm
Martin
Site Admin
Ignore these stuck-in-the-mud army boys Craig Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #76047 15th Jun 2011 5:10pm
