Home > Technical > Defender Alarm Weird Fault |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
My 65 plate was doing something very similar, alarm going off randomly and no power to the electrics. Losing the radio codes. It was found to be a bad negative connection on the battery post, looked ok but was intermittently causing the issue, it's a crap design of connector, eventually resolved by tapping the connector further onto the battery post and re-tightening the clamp bolt.
No issues since NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
19th Feb 2019 4:52pm |
benh78 Member Since: 29 May 2018 Location: UK Posts: 16 |
Hi
Thanks for the tip. My negative terminal looks good - I don't lose power to anything and have had the battery tested. But maybe it is a voltage drop somewhere when the ignition comes on. |
19th Feb 2019 5:26pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
I had a similar problem a couple of years ago on my 2015 90. The BBUS sounded in the middle of the night on two occasions for no apparent reason. It went off a third time for about 20 secs and then silenced, immediately the horns then started to blow continually. The dealer changed one of the horns, apparently corroded and has been ok ever since. Just wonder if one of your horns is faulty as it seems to be a similar fault. Defender 90XS SW
19th Feb 2019 6:03pm |
Thanks for that I'll take a look at the horns see if there is any corrosion
19th Feb 2019 6:05pm |
