Home > Technical > centre dash console |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2949 |
Not unless you get a complete Td5 dashboard
17th Feb 2019 11:36pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1851 |
I haven't the time or internet access to check properly at the moment, but doesn't the Raptor console fit without cutting? I could be wrong, and it's aftermarket, not LR, but worth a quick look to check. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
18th Feb 2019 9:07am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
The mud console physically fits over the lower dashboard without any cutting. You just cant fit anything with any real depth to it (i.e. radio, dials or switches) in the lower half without cutting the dash.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th Feb 2019 9:46am |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 |
"but doesn't the Raptor console fit without cutting?"
No, the Raptor console requires you to cut a section out of the lower dash. That said, when fitted it is an excellent piece of kit. ONE LIFE, GET IT! |
18th Feb 2019 8:27pm |
Bongo1 Member Since: 02 Nov 2018 Location: Cheshire Posts: 815 |
Shame i liked the Raptor with all the order options , But the MUD is ok . i only really want it for the radio up top and a few switches lower section . So perfect if no cutting .
22nd Feb 2019 11:08pm |
Just checked the MUD console , you do have to cut the dash . You would someone would make one that you dont need to chop the dash up .
22nd Feb 2019 11:23pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 |
The Raptor dash is a great bit of kit. Can I ask why you don't want to cut?
23rd Feb 2019 8:35am |
The whole point of these dash consoles is to provide space that the original dash doesn't but they're only going to work with the original removed.
If you really don't want to cut your dash then you could, instead, fit the earlier radio mount in the space between the vents and add extra switches to the oval recess inthe centre of the lower dash. There are various options for overlay plates for the latter that allow all sorts of switch and gauge combinations to be installed. I think Mud might do them but they're certainly available on eBay. Alternatively, you could build your own Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Feb 2019 9:37am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
2002 90 Td5 Station Wagon
23rd Feb 2019 9:51am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1439 |
As above, the point of a console is to fit additional accessories.
If you only want to fit a single radio, the MUD dash has a single position in the top angled face that can be used without cutting the dash. May not be suitable for some CD players that are prone to skipping if mounted at an angle. I'm sure switches could be fitted in the lower area with careful positioning or short depth. I was reluctant to cut the dash initially, but the convenience outweighed the concerns. If it was a pristine, 100% original vehicle I wouldn't do it. Click image to enlarge |
23rd Feb 2019 9:54am |
