Home > Td5 > Clutch adjustment?
lightning
Clutch adjustment?
Well, clutch pedal adjustment on my TD5.
The clutch biting point is a bit low. I have bled the hydraulics and adjusted the low stop screw. But the pedal at rest is about 1cm too low.
Trouble is, l can’t shift the two lock nuts on the master cylinder rod to adjust it. None of my spanners will fit (or if they do, you can’t turn them)
I was told to try it with the pedal pressed down, but l still can’t get a spanner on the inner nut, it’s also narrow so the spanner is too big.
What’s the solution?
Is there a special narrow/slimline spanner or do l have to make one?
Post #757303 8th Feb 2019 12:28pm
Mo Murphy
Make one, requires the sacrifice of a spanner. Once made you have it forever or until you lose it 😉
50 Shades of Pennine Grey
Post #757311 8th Feb 2019 12:50pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Clamp a pair of needle nose vise grip pliers (mole grip I think you guys call them) on the threaded shaft and use a wrench on nut.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #757327 8th Feb 2019 3:09pm
lightning
That’s an idea, thanks l will give it a try.
Also l have ordered two spanners to see if l can cut them down to fit.
Post #757337 8th Feb 2019 4:08pm
Procta
lighten check your master cylinder for leaks too, just in case. My dads had a problem. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #757376 8th Feb 2019 6:51pm
lightning
Can anybody tell me if a TDCi clutch pedal box/master cylinder is the same as a TD5 one?
Post #757800 10th Feb 2019 5:34pm
lightning
I can answer this as l have just fitted one.
Yes it will fit in place of a TD5 assembly, one mounting hole is in the wrong place but you can either leave it with five bolts or drill an extra hole.
The clutch switch is different on the TDCi. Although it looks the same, it’s a normally open switch where the TD5 one is normally closed.
So you also need to swap it with your TD5 switch, a very easy job which takes a couple of minutes.
After 100,000 miles the pedal mechanism had some play in it so now the clutch action is better, with less play before anything happens.
Plus the TDCi pedal has the assist spring already fitted and this makes for a lighter clutch action.
Post #759220 17th Feb 2019 4:23pm
lightning
I also figured out a way to get to the locknuts on the master cylinder rod without modifying spanners to fit.
Wedge the clutch pedal down.
Loosen the nyloc nut on the end of the master cylinder rod until it’s as far off the end as possible without falling off.
Release the clutch pedal.
The clutch pedal arm will end up against the nyloc nut, leaving the two locknuts clear of the arm and accessible with ordinary spanners.
Post #759559 19th Feb 2019 10:28am
lightning
OK so l have loosened the locknuts
Can someone tell me the correct resting position of the clutch pedal? The service manual says that the bottom of the pedal should be 140mm from the floor.
But it doesn’t say whether that is with or without the pedal rubber fitted.
Post #760442 23rd Feb 2019 7:46pm
4RF RDS
With... to bottom edge of pedal. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #760455 23rd Feb 2019 8:42pm
lightning
Thank you.
Post #760521 24th Feb 2019 9:30am
