![]() | Home > Maintenance & Modifications > Advice on repairing this paint damage |
A light sanding, clean with degreaser, etch primer wait 24hrs then touch up paint not sure on drying time prior to lacquer. There is some proper techers for blending if you search YouTube
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
Thanks Mash, much appreciated. The def is not quite 6 years old, is it worth a chat with LR re warranty or am I kidding myself?
Alitaff Member Since: 21 Dec 2017 Location: N-Wales Posts: 119 ![]() ![]() |
Hi,
I would temporary mask the surrounding area to save any scratches to the paintwork. Gently sand the damaged area and feather in the edges so you have a smooth surface. If there is any signs of oxidisation then you can use solution like ALI-CLEAN before painting, see attached photo. Once the area is thoroughly rinsed and dried then use couple of thin coats of etching primer which can be sanded down with 400 grit wet sandpaper after 20/30 minutes drying time. You can either spray the repaired area or use very fine artist brush to paint the area. The lacquer should be sprayed within 2 hours after spraying the top coat. ![]() Click image to enlarge Good luck 👍 |
