Home > Td5 > Oil depression control valve removal question
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Hi all, I would like to change my oil depression control valve LLN100140L. Has anyone any tips for removing the bottom part from the turbo hose. It appears to be permanently fixed with some sort of hose collar clamp. Is there a tool for removing this clamp and is there an easier way to fix the replacement ? Cheers Andy
Post #758040 11th Feb 2019 8:07pm
htb2
Wales
You could open it up with a screwdriver, there are proper pliers to refit.
Or cut it off with a hacksaw and replace with jubilee clip.
Post #758051 11th Feb 2019 8:31pm
landy andy
There are special tools to remove and refit. Not overly costly.
Post #758059 11th Feb 2019 8:51pm
AndyT66
Thanks both, after more googling I think it maybe a clic r clip, looks easy enough with the right set of pliers Thumbs Up
Post #758083 11th Feb 2019 10:26pm
landy andy
Yes that’s the ones Thumbs Up Thumbs Up eBay or Amazon sell them.
Post #758085 11th Feb 2019 10:35pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Can I ask what has led to it needing to be replaced? Symptoms?
Patrick
Post #758094 12th Feb 2019 2:21am
bankz5152
Ping it off with a screwdriver. Replace with a jubilee clip Instagram @defender_ventures
Empire Tuning - Agent
Post #758096 12th Feb 2019 5:40am
grafty99
You can clip them back together with a pair of end cutters if you're careful when you remove them Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #758100 12th Feb 2019 7:40am
AndyT66
Patrick
I haven't got any symptoms as such leading me to change this unit. However the surrounding area is covered in old oil and grime and I've read that some consider this bit of plastic which is subjected to hot gasses should be a service item. So I'm going to pop it off and have a look.
Post #758304 12th Feb 2019 11:47pm
Justtellme
Thanks!
Will be watching with interest.
Patrick
Post #758307 13th Feb 2019 2:18am
lightning
I changed mine for the same reason. “We don’t sell many of these” said the LR parts guy.
It made no difference but won’t do any harm to change it. I cut off the clip and replaced it with a plastic one.
Post #758982 16th Feb 2019 1:04pm
