Home > Off Topic > C-tek charger and a compressor |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
so I need to pump something up in the house to 3bar......
using a foot pump is proving painful and the item is up in the air and my little chicken breast pecks are done for..... anyone see an issue with rigging up the c-tek charger onto the 12v compressor that typically pugs into the 12v cigar / socket to do the pumping? |
7th Feb 2019 4:41pm |
doh.
erm...does that depend on the charger. I think I've got the 7amp jobby. .....just checked the compressor it's - 10amp |
7th Feb 2019 5:03pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17503 |
IIRC my 12V compressor (ARB twin) pulls around 60 Amps when running. I doubt that you'll run any compressor of a charger, although I suppose you might if it is a accessory-socket compressor (although one of those once melted the socket in my Disco2).
You could take the battery out of a vehicle and use that. Alternatively you could pressurise a receiver of some kind at the vehicle and then take the pressurised receiver in the house. |
7th Feb 2019 5:25pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
OR drag that spare car battery in the garage/shed out, connect the charger to that for an hour or two, then run the compressor off that.
7th Feb 2019 5:31pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2310 |
What is it, expansion vessel? Get yourself a hand bicycle pump? > 110 XS Double Cab
7th Feb 2019 5:41pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1321 |
Or treat yourself to a small mains compressor.
Lidl have some in next week if you can wait. And they have a 3 year guarantee. Not really big enough for powering hungry air tools, but handy for blowing up tyres or interior pressure vessels https://www.lidl.co.uk/en/MiddleofLidl.htm?articleId=20205 |
7th Feb 2019 6:16pm |
BobT Member Since: 13 Jan 2017 Location: North Yorkshire Posts: 110 |
I have the Suaoki U10 L.I. Jump Starter with a 12v cigarette lighter adaptor, it powers my compressor easily and I no longer have to plug it into the car and drag the cable about.
I’m sure it would do the job. You can also get 240v to 12v transformers for powering portable fridges that has the cigarette plug and that would also work. |
7th Feb 2019 6:44pm |
thanks guys. I suddenly remembered where I could get hold of an old car battery (save me taking it out of the car). anyhow grabbed it hoping there was still some charge in it and yes with the help of my daughter operating the compressor (a Ring jobby - I'm not suggesting they're great but for the cost and occasional use I reckon you could do worse) and me hold the cigar / aux plug against the battery and a long screw driver - hey presto job done. didn't have a suitable bike pump. and yes it was for an expansion vessel. had some bad luck with em. the first one that was installed didn't last too long and if I remember right it was for vertical installation but was installed horizontally and this the second one hasn't been in long...turns out the valve was leaking and just needing tightening up. hopefully no more water leaks now |
7th Feb 2019 6:47pm |
