Home > Maintenance & Modifications > Grease Nipple Help |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Hi folks,
I have looked back through the posts and I cannot seem to find the info, although I know I have seen it somewhere! My local indy is struggling to get grease into the UJ's etc, and I think I remember a post saying a Chainsaw Grease Gun will do the job. Is this the correct one: https://www.amazon.co.uk/Grease-Chainsaw-S...grease+gun Any help or other tips on getting this job done are appreciated. Cheers. |
30th Jan 2019 2:29pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello ChrisDefender
At each service I think it's just too awkward but the trick is to roll the prop shafts to allow a line of attack for the grease gun to get on the UJ nipple as square as possible, I use a short stubby gun that works well. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
30th Jan 2019 3:12pm |
Thanks chaps, I'll give that a go!
Much appreciated. |
30th Jan 2019 3:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
I always jack up one side, put it on a stand. Out of gear and wheels chocked of course.
Handbrake off if on the rear. And rotate the prop around to open at the widest point where the nipple is accessible. Usually the upper side neatest the top. I have never had any issue doing it this way, and of course you can take it off if you want but reference mark it so that it goes back in situ. Putting some in, rotating the prop a few time then adding more does the trick for me. There nearly always is more grease from some of the cups than others. There shouldn't be a problem using a grease gun with standard tip as long as it's not huge. Mine a Draper pistol type, I'm not saying it's absolutely excellent but it doesn't do the job. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Jan 2019 4:45pm |
Excellent, thank you.
30th Jan 2019 5:04pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
Id be a little worried about the indy you are using if they cant even sort that out. DEFENDER 90 TDCI XS,
30th Jan 2019 5:33pm |
^^^^ So would I. In fact I'm pretty sure many skip doing them all together. No Guts, No Glory.
30th Jan 2019 6:36pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
an alternative approach is to buy a couple of extended nipples. makes the entire job a POP It is not a Defender, it is a One_Ten
30th Jan 2019 7:39pm |
jocklandjohn Member Since: 16 Sep 2016 Location: Highlands Posts: 62 |
Something I didn't see mentioned (I might have missed it!) is - take it for a drive first to warm up the UJ's and soften the existing grease, and also take the grease gun inside overnight so its soft and warm too - will make getting it in much easier especially and particularly in January!
30th Jan 2019 7:42pm |
Good idea, only bear in mind it'd be easy to burn yourself on the exhaust if not careful and limited room. No Guts, No Glory.
30th Jan 2019 7:54pm |
Thanks for all the help and advice chaps.
All done and dusted now, they unbolted them to do the job properly and filled them up, feels much better now. Cheers all. |
6th Feb 2019 6:38pm |
