Home > Technical > Wiper and washers stopped working!
Page 2 of 2 <12
Tepidboy
Just a thought but when I tested the stalk I plugged the new one in but didn’t attach it to the steering column. Does it need to be earthed by the column to work ?
Post #756475 5th Feb 2019 10:54am
mk1collector
Are the wiper spindles seized? Ray
My build thread
Post #756482 5th Feb 2019 11:41am
Tepidboy
There is resistance when pulled but I think this is the motor.
What about the earth issue with the new stalk?
Post #756490 5th Feb 2019 12:13pm
No, the stalk isn't earthed by the column. It should work independently. Darren
Post #756491 5th Feb 2019 12:18pm
Tepidboy
So stalk checked, fuses checked, relay checked.... I’m really at a loss now ?!?!?!?!
Post #756619 5th Feb 2019 9:18pm
Have you checked if you've actually got power at the stalk, or anywhere else in the systems? As both washers and wipers have stopped, it's either a common connection point or a very strange coincidence. Darren
Post #756626 5th Feb 2019 9:38pm
Tepidboy
So I’ve been quiet as I’ve been busy!
Dash out and fault finding now on the wires. Manages to track it down to a fault on the green and red live feed( I think!).
I reckon it has failed on the splice for the washer and wiper split. This is the only split in the full length of this wire. But does anyone know where this splice is so I can inspect it?
Post #759631 19th Feb 2019 6:12pm
Ptarmiganevents
United Kingdom 2012 Defender 110 Puma 2.2 USW Aintree Green
Did you find out what the fault was in the end? My wipers and washer packed in yesterday so faced with the same issue and symptoms you have experienced 😟
Post #798595 18th Oct 2019 6:46am
Page 2 of 2 <12
