Home > Maintenance & Modifications > Do I need to undercoat Dirt Defenders before paint?
Co1
And if so, what would you recommend?
Thanks
Col
Post #756016 3rd Feb 2019 7:04pm
Sulisuli
Do you have the smooth or textured ones? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #756023 3rd Feb 2019 7:50pm
Co1
Smooth.
Post #756024 3rd Feb 2019 7:53pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Light scotch and plastic primer or pio from buzzweld than top coat and lacquer 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #756026 3rd Feb 2019 7:58pm
Sulisuli
Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #756028 3rd Feb 2019 8:03pm
VVS210
My thoughts would be yes. You will need a primer that is designed for flexible plastic, you can buy this in a spray can from Halfrauds in different colours - check the primer colour for the final paint colour. you'll also need panel wipe to degrease & probably worth keying the surface using suitable grade wet and dry. I'd also flat the primer back between coats, as well as between colour & lacquer coats.
Not painted dirt defenders but these were the last project I did - this is before the final flatting back & lacquering.
Post #756029 3rd Feb 2019 8:05pm
Sulisuli
VVS210 nice spray job, what are they? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #756034 3rd Feb 2019 8:12pm
A powder or spray guide coat can also be useful, especially for finishing primer before base coat.
You do flat with solid colours between coats but not with metallics. Thumbs Up
VVS - That took some time and effort for such a nice finish. Thumbs Up KEEP CALM AND Drill ON
Post #756038 3rd Feb 2019 8:23pm
grafty99
I just keyed and plastic primed mine before base coat and lacquer. Still good 18 months later Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #756074 3rd Feb 2019 9:58pm
VVS210
They're the shells to a pair of Peltor Sporttac electronic ear defenders. Did them back in the summer after a supposed professional did a Censored job starting with no primer & with a lot of overspray due to poor masking. Decided I could do the job better myself so I did!
Post #756076 3rd Feb 2019 9:58pm
Sulisuli
So still Defender based Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #756078 3rd Feb 2019 10:05pm
