![]() | Home > Td5 > Arrrrrrrrr! Electrical disorders : signal lights, rear wiper |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Fuses is your first thing to check. The manual shows you which fuses deal with which instrument. The fact that so many have gone at the same time, suggests that somehting more general might be at fault. An earthy perhaps.
Someone who is not an electrical ignoramus will be along to help in a minute. |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
After checking the fuses you may need this tool.
Pom |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
I think of the things you have listed only the hazards are not on a switched live circuit - check the fuses under the drivers seat.
Cedwat Member Since: 18 Jan 2010 Location: North Posts: 22 ![]() ![]() ![]() |
Ah ah ah ! That was good fun ! ![]() Well the car is still not working now ![]() |
Ok. I'll try that. By the way, I put a power box from ReulSport there yesterday. I had to get a permanent "+" from the fuse box and a earth also from there. But I checked my connection : they are clean and good. Did not check the fuses there. |
I am good again: it was the 10A fuse in the dashboard box (I think position 7).
Thanks |
