Home > Technical > td5 twin alternator , but just using the upper mount
razz
2001 Defender 90 Td5 PU Caledonian Blue
so your thoughts please , my old bus spends time under water and when it does , the usual warning lights come up , and the nanocom says shes down to a few volts , so using the twin alternator kit , how about i move the one alternator up out of the way ?? must be worth a go , as long as the standard belt reaches
Post #755329 31st Jan 2019 8:14pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Doesn't the TD5 alternator also have a vacuum pump for the brakes?
If you have to increase the length of vacuum pipe it could effect the brakes in a negative way, but I'm not sure.
Post #755382 31st Jan 2019 11:20pm
Yes it does have the vacuum pump, but there should be no problem extending the vacuum pipe provided suitable pipe is used. What would be harder is extending the oil feed and return lines for the vacuum pump.
Most twin alternator installations leave the original alternator and add a conventional (non-vac) second alternator.
You could disconnect the original alternator's wiring and just use it as a pump, or you could fit an electric vacuum pump.
Post #755402 1st Feb 2019 8:16am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
One question - looking for any info of placement second alternator in place of ACE (hydraulic controlled suspension used on Discovery 2) pump. I have A/C in our 130, so it is not possible to place the alternator instead of the A/C compressor. But there is some "empty place" used for ACE hydraulic pump. I don't want to reinvent the wheel, so any info is good. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #755403 1st Feb 2019 8:32am
landy andy
Twin alt setup, but for those that don’t have ac.
https://gwynlewis4x4.co.uk/product/td5-def...tor-mount/
Post #755416 1st Feb 2019 10:04am
razz
thanks for your inputs chaps , will keep on searching
Post #755722 2nd Feb 2019 5:47pm
