Home > Td5 > 2004MY Relays
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
2004MY Relays
I have three relays under my seat, Fuel pump, Glow plugs and Main. The first two are obvious but what does the Main supply.
Post #755301 31st Jan 2019 6:29pm
mturri
 2006 Defender 110 Td5 CSW Bonatti Grey
Main relay supplies the ECU - which in turn closes circuits to energise both fuel pump & glow plug relays.
The inertia switch is on the coil side of the main relay, likely the reason for its existence?
Post #755707 2nd Feb 2019 4:58pm
drakes
Thanks for that, I was thinking of interupting the supply to one the relays as a security measure but did not know which one would be best
Post #755881 3rd Feb 2019 11:06am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
IMHO the "main" relay is best, with a hidden switch, or better still a latching relay, that way it will still crank and appear normal but of course won't start with no power to the ECU.
With the latching relay option you'll need to energise it every time you try to start but it saves you forgetting to switch it off to immobilise.
Post #755884 3rd Feb 2019 11:11am
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
If you isolate the ecu does the alarm still arm? I assume central locking dies along with alarm...
Post #755979 3rd Feb 2019 5:10pm
drakes
Mine is poverty spec, no alarm or central locking.
Post #755998 3rd Feb 2019 6:02pm
drakes
Clive
I see your point about a latching relay so that you do not forget but am not sure how it would work.
When you energise the relay with a momentary switch it would latch but what makes it unlatch when you turn the vehicle off
Post #756006 3rd Feb 2019 6:23pm
Clive
No, the 10AS alarm ECU works independently from the engine ECU, doesn't affect the locking or alarm functions at all. (Not on a Td5 anyway.)
Post #756041 3rd Feb 2019 8:39pm
Clive
drakes wrote:
Clive
Feed the latching relay from a switched ignition source - switch ignition on, activate relay then start.
Switch ignition off, relay is de-energised along with the ECU. Thumbs Up
Post #756043 3rd Feb 2019 8:43pm
drakes
Yes Clive obvious really. I was thinking energise as soon as you get in the vehicle before switching on ignition and could not see how that would work. Should really have thought a bit more before asking the question.
Post #756048 3rd Feb 2019 8:57pm
