Home > Maintenance & Modifications > Best mod I have done
jst
Well certainly this time of year!
15mins of webasto later
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #755175 31st Jan 2019 7:31am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
A heated screen is a god send and was for me this morning Thumbs Up
How were your door seals/locks?
Post #755187 31st Jan 2019 8:19am
CarMan
Couldn't get into mine yesterday and had to take the wife's Golf Big Cry Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #755194 31st Jan 2019 8:56am
Mike c
I remember this happening to me with my first Defender back in 2010/2011 in the very cold winter we had, I had to use another car to get to work.
On this one I coated the door seals and locks in silicon spray to hopefully help stop this, my seals were fine this morning but my lock was a bit sticky as it wouldn't shut on the first few attempts. The lock freed up fairly quick.
Post #755197 31st Jan 2019 9:08am
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Gummi Plfege
Post #755207 31st Jan 2019 10:03am
Swine&Small
My thoughts exactly 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #755209 31st Jan 2019 10:09am
My Defender has just (yet again) suffered from a broken wire to the door lock in the second-row offside door, usually an easily rectified minor inconvenience. However it did occur to me over the last few days that this is useful protection against the Defender spontaneous-cold-weather-lock-out feature that some folk suffer from at this time of year. At least even if the car locks itself while I am de-icing, it can't lock the second-row door.
I do have a cunning plan to fix the second row door conduit problem for once and for all this weekend, weather permitting. I am fed up with the six-monthly broken wire repair!
Post #755219 31st Jan 2019 10:43am
TJH1985
Couldn't agree more Mr. Green it has been nice to watch the neighbours scraping their cars when you come out to a warm fully defrosted defender Cool
My Skoda has struggled to get up to template on its 14mile commute, the defender is fully up to temp within a few streets after a pre heat with the Webasto.
Looks like your defender has better insulation though as mine clears the bodywork as well Rolling with laughter
Post #755221 31st Jan 2019 10:50am
jst
insulation.......ermmmm
mine has a block heater (thermo top C) fitted against bulkhead on passenger side - hence its cleared there! so engine lovely and toasty.
Also has an Airtop under the 2nd row of seats for the interior so lovely warm inside too without sacrificing heat to the engine block. i fitted both around 2k miles old.
Both are on timers and run off 2nd battery on split charge.
Heated screen is also wired into heated door mirrors which is a good mod but need the engine running!
heated rear seats the kids love! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #755248 31st Jan 2019 12:41pm
grafty99
Van sliding door contact pins? Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #755250 31st Jan 2019 1:12pm
mk1collector
The wife’s has also broken again so I’ll look forward to hearing about your solution Thumbs Up Ray
My build thread
Post #755264 31st Jan 2019 2:32pm
I had half an idea to use some curly cable, the next time I have to repair one. Darren
Post #755298 31st Jan 2019 6:06pm
yostumpy
You can make curly cable, wind it tightly around a biro, leave for a while then slide biro out, has worked for me before, but the thicker the plastic covering, the less chance. 'Volvo XC 70, taking the rough with the smooth’
Post #755409 1st Feb 2019 9:14am
